Question about Dell Inspiron 6000 Notebook
I have a Dell inspiron 6000 battery problem
I have a dell inspiron 6000 and when I first turned it on the battery was fully charged and worked. I unplugged it to see how long I could work with the laptop with it unplugged. Well it seemed to be draining at normal speed..then it died..instantly. Now when I plug it in it won't charge. It says it is charging, but remains at 0%. Also, I can get the battery charging light to come on when I turn off the computer for a short period of time, then it stops. Also, the battery itself when I press on the check battery none of the 5 lights go on.
Thanks
Linda
  • 499 Answers
Try to remove the battery out from ur laptop then clean its terminals from any corrosion (By scratching it using a screw or something like that) then after 5 min. try to install it back again then connect the laptop to the charger hope it works
Posted on Jul 22, 2009
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
Purchased a new Dell Inspiron 6000 (9 cell) battery
You just want to refresh battery from the BIOS. There problem will be solve
Mar 15, 2010 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 battery light is orange
remove the battery and insert again. if it continues then you will have to check the power source perhaps current it not enough for charging, if it continues then you will have to get a new battery
Oct 11, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 not charging
suspected faulty battery. replace the battery.
May 28, 2009 | Dell Inspiron 1501 Notebook
Battery wont charge
pls consult ur service center forthe problem & if this under warranty contact dell directly for this issue......................Sameerayan
Jan 17, 2009 | Dell Inspiron 6000 Notebook
Labtop not charging
Try removing the battery and see if the laptop powers on. If it still doesn’t power on then either the motherboard is defective or the AC adaptor may have a broken wire in the cable.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 03, 2008 | Dell Inspiron 6000 Notebook
Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
Jul 10, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
204 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
