hi i have just bought a new radeon x1650 pro 512mb graphics card and ive removed the drivers from my last graphics card and placed the new radeon into my computer. but when i turn it all on to install the drivers i get no picture on my monitor, i just get that blue screen with RGB on it, whats the problem? specs are as follows:
CPU: AMD sempron 3000+ 2.0ghz, core voltage 1.6v
motherboard: american megatrends, K7S41GX graphics interface AGP 8x.
When the card is properly installed and the system properly configured, you should at least be getting the POST screen, since that is not driver dependent. And Windows knows to go to the default standard VGA driver when it can't find specific drivers for a card. So we're looking at a hardware issue, not software.
Here are the troubleshooting steps I would take. Some would seem obvious and you've probably already tried them, but I like to be complete:
Is the monitor switchable betwwen two inputs? Do you have it set to the correct input (i.e. VGA vs DVI)? hit the selection button on the front panel, just in case.
Is the card properly seated? Take it out and put it back in. Also, oddly enough, reseating RAM can fix a lot of problems, even seemingly unrelated ones.
Is there an on-board VGA connector? If so, switch over to that and see if you get picture. Then go into CMOS settings and look for a video setting that would make the add-in card the default display. Or simply disable the on-board VGA.
Check the pins on your monitor connection, make sure none are bent.
If none of these get you a picture, I would suggest a defective graphics card.
Yo quiero comprar una ATI RADEON 9250 Radeon 9250 o una GIGABYTE TRADEON 9700 ProRadeon 9700 Pro.......
(More)
Yo quiero comprar una ATI RADEON 9250 Radeon 9250 o una GIGABYTE TRADEON 9700 ProRadeon 9700 Pro.... o un ASUS V8200 T5 GF3 Ti500. Me hacen falta para dos ordenadores con placas base:P4i65GV (Asrock) y el otro es placa base K7S41´GX (Asrock) Los dos son Pentium IV y necesito AGP o VGA apropiadas para ambos. Claro que a poder ser 4X. Les quedaría sumamente agradecida si me mandan información y precios. Saludos.
Microsoft DirectX* Diagnostic Tool (dxdiag.exe) shows AGP Texture Acceleration is "Not...
(More)
Microsoft DirectX* Diagnostic Tool (dxdiag.exe) shows AGP Texture Acceleration is "Not Available" on the "Display" tab. Do u know how i can get one or what to doo i can play game that i play on fx5900 zt help
