Have to reset ma cell from standby mode
Dear sir my o2 xda exec screen goes black when power button pressed or goes in saving mode n then am unable to switch it on using the same button..have to do a reset to switch on ma set..plz help
  • 8 Answers
SOURCE: o2 xda exec
This is the suggestion they provide on O2 website for such problems:
  • Perform a soft reset (PDA phone) or re-boot the device (Smartphone) and test again.
  • Perform a hard reset (PDA phone) or return to default settings (Smartphone) and test again. (read below before dong this)
  • Check that the application still fails to execute after you upgraded the ROM (OS) to the latest revision. If you haven't upgraded your ROM (OS) do so now and check again.
But before doing the hard reset, I suggest you try installing other camera software for windows mobile 5 and check if the camera still working (not a hardware problem). If its still fail, try the hard reset after backing up all you data.
Posted on Feb 01, 2008
SOURCE: xda exec
radio signal crash and have to reboot?
Posted on Apr 01, 2008
  • 3 Answers
SOURCE: dopod 900
i have problem cannot on ...only black screen ... battry is ok ... cannot go to bootloader ... i think all data bios and memory lost ...can u help me
Posted on Jul 13, 2008
SOURCE: o2 xda exec
I had the same problem. The issue seems here that the battery keeps getting honked off. I changed my charger and did a defragment and also did some files sytem clean up using Pocket mechanic. That solved the problem.
Cheers! Manik
Posted on Jan 02, 2009
SOURCE: I need to know about a service centre in Bangalore for O2 XDA EXE
Uccom service center
215/16 gnd floor, knm complex,
28th crs, 2nd blk rajaji nagar, blr 10
Back side of Rajajinagar RTO office.
080-23529344
022-40333999
o2indiahelpdesk@gmail.com
Posted on Feb 10, 2009
I have a xda exec phone .the screen is blank with a serial up and 1.0v down the screen .. pls tell me what to do ..
Your phone is in bootloader mode. If you have not intentionally put it in that state, it might have entered it after an usucessful ROM upgrading process. Anyway, to get out of that state, just soft reset your device. The reset pin is located at the left side (in portrait mode, or at the back of the phone, when its screen is slided open). Just lightly press that pin with the stylus pen.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Feb 27, 2012 | O2 Xda Atom Exec Smartphone
Tip
HARD RESET
With the device open, press the two soft keys together while pressing in the reset button on the back of the unit with your stylus. If done correctly you should see a screen that says "Press 0 to reset to factory defaults or X to exit." Press 0 to confirm the factory reset
HTC Universal T-Mobile MDA IV Vodafone VDA O2 XDA Exec i-mate JasJar Q-tek 9000 Orange SPV M5000
on Mar 10, 2010 | Cell Phones
My Phone does not switch on.
Perform a hard-reset.
At the expense of your data-loss,
atleast you get your device working back.
To perform a hard-reset on your O2 Xda Atom,
Keep pressed the POWER key, and then perform soft reset. After the device this leave everything and confirm that you want to hard-reset as shown on the screen.
Please rate...
Sep 12, 2009 | O2 Xda Atom Exec Smartphone
My Dopod 900 (aka O2 Xda Exec) White Screen Problem
if you have a lot of data on your phone, do a sync. if it synched properly, if it does, probably the flex is damaged or the screen alone. try to press all the buttons on ur pda phone. if they all make a sound (if your sounds for keys are enabled, i hope) your flex is alright. have your LCD changed. try to tap your screen also if it makes a a sound... Hoping to be of help to you.
Apr 13, 2009 | O2 Xda Atom Exec Smartphone
How can i hard reset my o2 xda orbit?coz i 4get ma password..
To do a hard reset.
Press both soft keys and insert stylus into soft reset button and press.
Release the soft reset button and keep pressing the soft keys.
When the "This operation will delete all your personal data, to manufacturer default" appears on screen.
Press Green call button to restore manufacturer default, or press other keys to cancel.
source
http://wiki.xda-developers.com/index.php?pagename=Artemis_Resets
more helpful information about your device:
http://wiki.xda-developers.com/index.php?pagename=HTC_Artemis
Let me know if you need anything else.
Thanks,
Ekse
Mar 07, 2009 | O2 Xda Orbit Smartphone
Factory reset O2 Xda Atom Exec Smartphone
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
Feb 08, 2009 | O2 Xda Atom Exec Smartphone
O2 xDA Atom Exec Screen Blank After SofReset
Couple of things you can try to fix the issue, firstly try a hard reset
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. *Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost
Try that and if it doesnt resolve the issue then we can try another solution
Aug 23, 2008 | O2 Xda Atom Exec Smartphone
Unable to boot up my O2 Xda Atom
Dear cafei,
Go to boot loader on your O2 XDA atom by removing batt+pressing camera button+plugging in the batt back WHILE still press holding the cam button the ue the stylus to press soft reset button, then connect to your pc via usb, then run the update program (most refer to it as DSUU, u can download one from seeo2.com) just wait for the progress to complete and you're done.
if in case you get stuck at 6%, unplug usb cable, remove battery, then insert battery while press holding the power button, while still holding the power button, press the reset button with the stylus, it should show the o2 splash, wait for any progress. then re-run the DSUU again to perform full flash.
disclaimer:
please take note that i did not suggest any 3-party rom, it is best if you try the O2-released ROM (or DSUU).
Jun 02, 2008 | O2 Xda Atom Exec Smartphone
O2 Xda Atom Exec cell shut down; can not turn back on. one time black screen white letters came on, last read said looking for usb port to down load?
The Black screen that you are talking about is the bootloader of your PPC. Its just like the BIOS of your Computer.
There might be some problem with the Operating system of your O2 Atom Exec.
Try a hard reset by holding the Power Key and then soft reseting.
I know that you will lose your data, but you may get your PPC working back.
Please Rate if this is helpful.
Apr 22, 2008 | O2 Xda Atom Exec Smartphone
Computers & Internet Logo
David Payne
David Payne
