Question about Panasonic DVD & Blu-Ray Players
Panasonic cw8124 dvd slot drive problem
I can;t get my pc to recognize the drive - i plug it in via usb, I get power, I can insert cd/dvd and hit button to get cd/dvd backout, but it never shows up in devices - any thoughts?
4 Suggested Answers
  • 234 Answers
SOURCE: Not recognizing any DVD inserted on my DVD player
dust in lens mean dvd does read! clean the lens with disc cleaner! some problem comes again mean you want to change the lens!
Posted on Jul 01, 2008
  • 8596 Answers
SOURCE: Unit does not recognize usb flash drive.
Use a 2GB or less compatible memory card - Sandisk is the best bet.
Posted on Sep 04, 2008
  • 25 Answers
SOURCE: Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Posted on Sep 25, 2009
  • 36 Answers
SOURCE: Hi, I have a problem with HDD in DVD recorder
unfortunetly not
Posted on Feb 15, 2010
0 characters
1 Points
Why can't my Panasonic DVD recorder read my portable harddrive? I want the DVD record to read the harddrive?
hi anonymous, it may well be that you need to change settings on your DVD Recorder and/or on your TV. On my LG 42" TV I need to select the input mode ie. Movie, USB, music etc, as necessary. Maybe your DVD Recorder or TV can't handle the file format on you Portable Drive, check the manufacturer specs.
Jun 08, 2014 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic sa pt860
Check your USB memory to make sure that it comply with the points below:
1) USB standard USB 2.0 full speed
2) Media file format support MP3 (.mp3) WMA (.wma) JPEG (.jpg) (.jpeg) MPEG4 (.asf)
3) USB device file system FAT12, FAT16, FAT32
4) USB Port power Max. 500 mA
As you can see
1) You should format your USB in windows format (FAT system)
2) The files on your USB should be those mentioned above on point 2.
3) 2.5" hard drives most likely do not work without an external power supply.
you can download the manual from HERE !
Please don't forget to rate me!
Best Regards
Dec 14, 2013 | DVD & Blu-Ray Players
DVD player will not recognize any disc
That cd play will not read the format on the ****,you need to try a diff type of disc
Sep 04, 2012 | Panasonic DVD & Blu-Ray Players
Sharp BD HP21 Won't recognize USB drives
You have to make sure the files, you downloaded to your USB stick, are not in folders. Mine worked after this. I am still having problems with pixelation on newish discs. I read somewhere that if I plugged a USB thumb drive into the Sharp HP21 it will aid the processing and work better. Does anyone know if this is true as I often get poor picture quality on what looks clean LoveFilm BR discs. (No problems with standard DVDs.)
Sep 30, 2009 | Sharp AQUOS Blu-ray Disc Player
DVD No Disk Inserted
Hi. the mother board will acknowledge a no read as (no disc) if the optical lens assembly has failed. two issue here, the tracking motor and lens have failed. you will need to replace the entire optical lens assembly in this case.
Jun 03, 2009 | Denon DVD-5900 DVD Player
Disc won't eject, stays in "RECOVER" mode
look on the face of the machine, near the dvd slot. what you are looking for is a tiny hole, the size of a pencil lead. some players, not all, have this manual release. If you are fortunate enough to have one of these little holes straighten out a small paper clip and use it as a wire to insert in the hole and release your dvd.
May 23, 2009 | Panasonic DMR-E80H DVD Recorder
I have the Kenwood DDX512 and I cant get it to play music from a USB drive.
You will find the latest firmware listed there, 2.4.0. The unit ships with 1.0.0 which did the same thing for me not playing anything or even recognizing the USB device.
Download the file, unzip it and burn the included file, k08v5_update_78ca9780_2.4.0.ruf , to a cd. Put the cd in the drive while its running and it will automatically update your system. Make sure the vehicle is running at the time to ensure you have adequate power ... if it shuts down in the middle of it you'll brick the system.
It will restart, eject the cd and thats it. Plug in your USB device and it starts playing automatically.
Jan 17, 2009 | DVD & Blu-Ray Players
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Wharfedale DVD1100 PLayer does not detect USB Hard drive
It's unlikely that you're doing something wrong. Did you buy this DVD player as one that is supposed to support connecting hard drives? If not, then the player probably doesn't support connecting a hard drive.
Jan 08, 2008 | Wharfedale DVD-M3 DVD Player
DVD & Blu-Ray Players Logo
13 people viewed this question
Top Panasonic DVD & Blu-Ray Players Experts
Are you a Panasonic DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
