Question about RCA HD52W58 52" TV
D52w14 Won't turn on
When I turn the power on the light comes on and turns off three times and does not come on. It doesn't matter if I use a remote or the power button on the tv set
4 Suggested Answers
timinwga
  • 3 Answers
SOURCE: rca d52w14 power off
Same problem. It would TRY to come on 3 times, but nothing.
Mine was the Capacitor (cp150) that others talk about down in some of the other postings. I replaced the capacitor (man, what a pain it was taking apart all those plugs, etc) but that was the problem. I upgraded to a 35v 2200uF because radio shack didn't carry the 16v 2200uF.
It took me about 2 hours to complete this task of unscrewing the 20 screws (star-head screws, btw) on the back of the unit, unplugging about 10 connections inside, just to get the Printed Circuit Board (PCB) to twist out so that I could get to the capacitor and do the soldering. I suggest that if you use the radio shack replacement that you locate some type of insulation (black high quality electrical tape will do in a pinch) to put around the leads, because the capacitors look different than the one that you take out and the size is a little bigger and you have to leave the leads longer because it goes in sideways and you don't want them touching the metal [_] piece later on and shorting out.
I'm a novice at this fixing my own stuff game and this is only my second attempt and thus far, thanks to THIS WEBSITE, those who I have followed the advice of has worked. This was much more difficult than the monitor that I repaired 6 weeks ago. Saved me $250 for a new one.
Fortunately, on this model TV, all of the plugs/ribbons that you have to undo to get the PCB to twist out, all only have only one place that they will fit back together in.
The only reason for my post is to tell you that if a city cop with very little basic understanding of circuitry can do it, you might can as well. The capacitor costs $4.89 and it took me about 2 hours total from the time I turned the TV around to work on it, until the time I set it back around and turn it on. I've no idea what a TV Repairman charges per hour, but for two hours of work, it would've been a healthy fee + the markup on that capacitor.
I have no idea what a flyback is but it costs $60 at that website that they advertise in other postings. I tried the capacitor because: A) it was a cheaper fix, and B) I felt like my unit was getting power because the green light would come on in front. Good Luck! -Tim (30117)
Posted on Oct 22, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
SOURCE: tv will not turn the green light comes three times but screen comes on it is a rca 52 in d52w14
When mine did that the bulb needed to be replaced. Easy to replace the bulb.
Posted on Dec 27, 2011
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Nov 01, 2017 | Philips 32PFL3504D 32 in. LCD TV
What's your problem?i have a rca tv model number d52w14 and it will not turn on just the power button comes on and goes off three times?
The set actually has a "3 strikes and you are out design".
It will try three times and if fails shut the set down.
This model is prone to bad solder connections at and near the high voltage transformer---also to bad parts in that same area which include: the transformer, the sweep transistor near it, and the high voltage splitter block it feeds.
6_12_2012_3_08_16_pm.jpgTypical high voltage transformer that is also called a FLYBACK.
Jun 12, 2012 | Televison & Video
My Dish 5.0 IR remote won't program to my new TV, it's an Emerson, the model number on the back is- LC320EMXF. I've tried holding the TV button until all the top lights flashed and then...
lrsnihe
You were attempting to perform a power scan initially. The second procedure is manually attempting to address the remote to your TV. I will give you the procedures again so you can try one more time. Emerson TV is one brand we have a low percentage of success getting our remotes to work. If it still doesn't work, we could try replacing the remote.
TV code: 623, 667, 666, 233, 516, 537, 544, 642, 655, 699, 000, 999, 888, and 720.
Remotes: Basic (Television Only)
  1. Turn the Television On.
  2. Press and hold the clear TV button for six seconds until the LED flashes.
  3. Enter the three-digit code using the buttons on the number pad.
  4. Press #. Note: The LED will flash three times.
  5. Test functionality with the TV.
  6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Remote Power Scan: Basic Remote (Television Only)
  3. Press and release the red TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off once every second.
  5. After the television turns off, press and release the # button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Jun 12, 2011 | DISH Network IR Remote Control
Rca d52w14 power light comes on briefly then goes
1. the supply had a fault and needs to be repaired or replaced.
2. www.partstore.com might have your supply or you can pre order it from them.
Good luck hope this inforamtion does help when it doubt get a service guy to come out.
thanks and please rate.
Aug 22, 2009 | RCA HD52W58 52" TV
Rca d52w14 hit power green light blinks three times wont come on
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca tv d52w14
replace the flyback 25296 and the CP150 and CP114 capacitor. You can get the flyback and the capacitors at the following link and they provide free installation instructions with pics so you can easially do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Jan 17, 2009 | Televison & Video
Rca will not turn on
16v 2200uf capacitor on the 6v power supply bad top of capacitor usually domed
Aug 17, 2008 | RCA HD52W58 52" TV
RCA HD52W58 52" TV Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
