Question about SanDisk Sansa MP3 Player
My sansa Express won't charge or connect to my computer!
Well........umm i've had my sansa for couple of years, once i tried to synic music on it using winamp. it was hardly connecting to the computer. i ejected it, but when i triedto plug it in back....It was connecting and couldn't show the USB connection sing on the screen, but it was still working properly except the battery was low.
i listened to it for couple of hours then the battery went flat, i switched it on n' it said "BATTERY LOW". well i plug it in the computer again n' i wuldn't connect or charge!
So could someone PLEASE help me cuz i dunno how to fix this problem?
  • young_gun578 Jul 23, 2009
    so u mean.......i just plug it in the n' leaving it in all night, but even if i do that i wont charge cuz when i plug it in it does show any connection to the comp.
    i tried to leave it for couple of hours n' still it didn't charge! maybe i shuld call customer care? do u kno the number?
    Problem Solver:
  • 9 Answers
Try leaving it in the computer charging over night... if that doesnt work, call custumer care!
Posted on Jul 22, 2009
My sansa mp3 will not charge on my computer it just drains the battery instead. I have tried rebooting my computer but it still will not charge.....help I miss my music !!
Not all computer USB ports put out enough current to charge the battery. If you're plugging the Sansa into a USB hub, try plugging it in directly. If there's another USB port available, try that.
If that doesn't work, you may have to get a separate USB charger, as used for some cell phones.
Also, bear in mind that when the Sansa is connected to a computer, you can't listen to your music on it.
Oct 21, 2010 | SanDisk Sansa e260 MP3 Player
My Sansa Express MP3 player does not show up on my computer as "Sansa Express" but is shown as Removable Disk (K:). Is this right
Normally your Sansa Express would show up as "Sansa Express", which would indicate that it is in MTP mode. The Sansa Express doesn't supply a menu option to switch to MSC mode, which would cause it to show up as a "removable disk". Apparently your Sansa Express has somehow switched to MSC mode. MSC mode is necessary for upgrading firmware, in which case it's called "recovery mode", and it's possible that some combination of key presses (usually involving holding down the power/hold button) put it into this mode.
If you double-click on "removable disk (K:)", do you see a Music folder? If so, is there anything in the Music folder?
Feb 11, 2010 | SanDisk Sansa MP3 Player
Sandisk Express will not turn on.
Ensure that the player has been charged.
Try to power reset the device by simultaneously pressing and holding the center and volume up button, while connecting it to the PC.
If power reset fails, charge the device for at least two and a half hours. The computer should not be in sleep or hibernation state while charging.
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
Jan 14, 2010 | SanDisk Sansa MP3 Player
Player not recognized and won't turn on. Sansa Express 1gb.
Try another service pack on your windows XP or use Winamp ( Newest version ) To transfer music to your mp3 player.. hope it helps :)
Jun 19, 2009 | Audio Players & Recorders
My sansa express mp 3 player is stuck can't turn it off
Do a hard reset on the player, all settings will be lost. songs will remain.
To perform a hard reset, press and hold the Select button while pressing the Volume Up (+) button.
Key combination might vary
May 29, 2009 | SanDisk Sansa MP3 Player
I am wanting to delete music
Go to my computer scroll to sansa and open the music folder and open each sub folder and delete manually then delete the folders themselfs then format a couple of times hope this works
Mar 23, 2009 | SanDisk Sansa e260 MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
Apr 06, 2008 | SanDisk Sansa e260 MP3 Player
Sansa won't charge or load.
Plug it into the computer (the cord you would use to charge it and transfer files), and hold down the power button for at least 15 seconds. The Sansa should then begin to turn on and start charging. :)
Aug 07, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
505 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
