Question about HP LaserJet P2015 Printer
Hp P2015 printing black pages
Prints about 1" of text on the top and bottom rest of page is black. already changed toner cartridge, problem still there. problem is intermittent. any help would be greatly appreciated.
    President:
  • HP Master
  • 1,447 Answers
It is the problem laser unite
Posted on Jul 22, 2009
Black lines
Replace the toner cartridge :-)
Apr 05, 2014 | HP LaserJet 1020 Printer
HP Laserjet P2015 serires Could you advise me on how to get rid of a black line appearing down the centre of the page when I print please? Thank you.
Dirty print out is basically due to cartridge related issues. HP Laserjet P2015 uses HP53A Cartridge.Take out the cartridge and inspect it under torch light. You would notice the line(s) on the green drum. Gently clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is located under a cover which can slide with a little push. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Please note that, this step may help temporarily, if the cartridge and its parts are worn out. In that case it is always better to replace the toner cartridge.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located just behind the green drum inside the cartridge. Try to clean it too. It requires a bit of improvisation because it is difficult to clean it fully. If the problem persists, replace the toner cartridge with a genuine one or get the PCR Roller changed by a professional. If the cartridge is old
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 16, 2011 | HP LaserJet P2015dn Printer
Printing blank pages
First step : Try to pull-out toner cartridge then shake it and insert again test print. if same problem appear.
Second step : change new toner cartridge.
third step : Try to contact HP service center.
http://www.hp.com
Jun 03, 2011 | HP LaserJet P2015 Printer
Hp 2840 was printing light in black, so I replaced the cartridge, did a clean run print from tray 1 & now it only prints 1/2 a page from top to bottom. I shook cartridge installed again turned the...
Dumb question. Did you pull the strip from the toner cartidge? OEM or aftermarket? I would try the old cartidge and see if it changes if you don't have the old cartridge anymore I would contemplate replacing the one you just purchased or taking it back to where you purchased it and get an exchange for a defective cartridge.
Feb 10, 2011 | HP LaserJet 2840 Printer
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
I have an HP LaserJet1020 printer. When I try to print a document a 2 inch wide area the full length of the page on the right side of the page) will not print. If I change to landscape printing, the same...
Run the 1/2 print test.
Print a few pages that have failed previously and as the printer is printing open the cartridge cover(top cover).
Pull out the cartridge and look at the paper down below. If the page looks good, you probably need a new fuser. If the page is messed up you could have a bad transfer roller or another bad toner cartridge.
Dec 19, 2010 | HP Office Equipment & Supplies
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
HP p2015 printer has stopped printing
check inside the toner door on the right side. there should be a plastic tab which opens the laser shutter when the door is closed. if this is broken then the lase shutter will not open and will produce blank pages.
Jan 15, 2009 | HP LaserJet P2015 Printer
HP Laserjet 4250 printer black band 1 inch top of page
Before replacing the LVPS, I surely would replace the toner and transfer roller at same time.
Dec 20, 2008 | HP LaserJet 4200n Printer
HP Laserjet 1100, band of unprinted area after new toner install
Hi Friend,
You have mentioned this is a 2nd hand printer,
you have to service the printer,(fuser unit)
if the problem exists after fuser service check Laser Scanner also,
Thanks
Lux5
Nov 28, 2008 | HP LaserJet 1100 Printer
HP LaserJet P2015 Printer Logo
425 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
