Question about ECHO, Inc. 20 In. Double Sided Hedge Clipper
Echo SAM 2201 Weedeater - Problem: Fuel going through exhaust, flooding engine. While cranking engine, without using choke, fuel goes through the engine and comes through exhaust.
  • 155 Answers
Hi can be one of 2 things, Dirty fuel which will get on needle and seat or the diaphrams have gone hard holding the needle open.
Posted on Jul 27, 2009
Won't start, gas out of exhaust
Sounds like its flooded : excess fuel / wet spark plug.
Empty tank / Clean and dry spark plug. test plug for spark before refitting. If strong spark refit plug / and see if fires when turn engine over.
If it does then refill tank with new clean fuel and attempt to start without choke to avoid flooding.
May 25, 2016 | Toro Garden
Gas coming out exhaust
The machine is completley flooded, remove the spark plug, switch the ignition off, crank the engine until no more fuel is expelled from the plug hole, allow the machine to sit for an hour, replace the plug and try to start using full throttle and no choke.
May 29, 2013 | Garden
Is it the carbeurator if the chainsaw is flooding?
`It could well be the carb flooding, however if you have been cranking the engine for a time without it starting it will keep drawing fuel into the cylinder, you need to remove the spark plug, switch the on/off switch to off, make sure the choke is off, crank the engine until no more fuel comes from the open plug hole, now leave with the plug out to allow it to dry out, refit the plug and try to start with no choke and wide open throttle.
Dec 28, 2012 | Stihl Models 064, 066, Ms640, Ms660
Echo pb500t stallas when choke is opened
might check the exhaust port and muffler spark screen
Jul 19, 2012 | Echo Gas Blower 162 MPH 450 CFM Blower...
Outboard engine hard to start.
Press the key inwards to activate the Choke. Also, you only pump the bulb when the tank runs dry. Pumping after a successful run, shutdown, pump and restart can flood the engine.
If that doesn't work, claim under the warranty.
specs
Yamaha F20LEHA Outboard Motor Portable
manual, which oddly, doesn't mention a choke feature.
http://www.yamaha-motor.com/assets/service/manuals/1/LIT-18626-07-17_1378.pdf
Apr 19, 2017 | Boating
Started PB620-ST yesterday with some difficulty. However, ran until fuel empty. Refueled today, but will not start. Spark at plug ok. Fuel flowing, but seems to overflow into air filter compartment. ...
Sounds like your flooding the engine; I did the same thing. Wait a while to let the gas drain back to the tank. Use your primer bulb once and your choke for only ONE pull; then shut off the choke. Pull start without the choke 2-3 times and it should start.
Apr 30, 2011 | Echo Gas Blower 185 MPH 900 CFM Blower...
Saw floods out at initail start. Saw turns off after releasing ths gas trigger.
Are you following the correct start procedure? make sure the air filter is clean, switch the ignition on, pull out the choke fully, if fitted, engage the half throttle lock, crank engine un til it fires once, push the choke fully in, do not continue to crank the engine with the choke out after the first fire, crank the engine again until it fires up and runs, if you are following this procedure and still have problems, then the rubber tipped needle in the carb is leaking, if you have a bulb pressure tester connect it to the fuel inlet on the carb, pressure up to 2 psi, the needle should be steady and no leak, if you do not have a tester, you will have to remove the carb and replace the needle as a matter of course, let us know if you need help with this.
Feb 26, 2011 | Echo Garden
Fuel pour from exhaust after engaged choke for first time since have owned it . RD250 78 model
the fuel tap and carbs need cleaning.
fuel has flooded into the engine, and when you kick it it is pushed out the exhaust.
The choke is not the cause
May 18, 2010 | Motorcycles
Have an Echo Weedeater GT2000; just cganged the
check fuel hoses for tears as you prime make sure two screws are tight that holds the primer bulb
Aug 19, 2009 | Garden
ECHO, Inc. 20 In. Double Sided Hedge Clipper Logo
594 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
