Question about Texas Instruments TI-30XA Calculator
How do you divide the denominator into the numerator on the TI-30
Does the TI-30x have an inverse function to convert a feraction to a decimal?
Yes, you hit the yellow 2nd key and then the back arrow (it says F D above it in yellow.) It's the last key on the bottom of the left hand row.
Posted on Aug 19, 2009
Testimonial: "I finally figured it out by trial and error. Thanks for the help"
How do I get the TI-85 to convert an improper fraction to a mixed number?
To do this on any calculator, enter the numerator and denominator of your mixed fraction, with a divide in between. I get 1.4. Next, take the decimal into a fraction and reduce it to lowest terms. In this case, 0.4 converts to 4/10 which reduces to 2/5. Putting the two pieces together, we get 1 and 2/5.
Good luck.
Paul
Jun 24, 2015 | Office Equipment & Supplies
How do I convert fractions to decimals on a TI-86 calculator?
Just divide the numerator by the denominator. For example, to convert 1/4 to decimal, press 1 / 4 ENTER and see .25
Sep 15, 2014 | Texas Instruments TI-86 Calculator
How do I convert a decimal into a whole number?
You can do that only if the decimal part (the part after the decimal point) is exactly 0. Anything else will be a rational number { a fraction with integer numerator and denominator}
Feb 20, 2014 | Texas Instruments TI-83 Plus Calculator
Fraction to decimal function not working,only reducing decimals not converting them to fractions when using proper 2nd function option
To force the calculator to display a result as a decimal number, try putting a decimal mark at the end of a numerator or denominator. If you are using radicals, put a decimal point at the end. Example: enter square root of 2 as SQRT(2.). Notice the decimal mark at the end of 2.
Jun 13, 2012 | Texas Instruments Ti-30Xs Multiview...
Hello where is the fraction button on the ti-84 plus silver edition
There isn't one. If you want to convert a value from decimal to fraction, use the >Frac function (press MATH 1). If you want to enter a fraction, simply enter the numerator, divide, then the denominator.
For example, to calculate 1/4 + 1/3, press
( 1 / 4 ) + ( 1 / 3 ) MATH 1 ENTER
and you'll see 7/12.
Oct 21, 2010 | Texas Instruments TI-84 Plus Silver...
Convert
Transforming 0.175 to fraction:
= 175/1,000
Reduce to lowest term (divide by 5 both the numerator and the denominator):
= 35/200
Reduce further by dividing both by 5:
= 7/40
This is the lowest terms now that it can't be reduced further.
The "Other" way round, Bottom number into ONE and multiply it by the Top. EG: 3/4 == 1 divided by 4 = 0.25, now we multiply, .25 by the Top number or in this case 3, that equals 0.75. 1/4 =0.25 x 3 = .75. 3/4 is the same as 0.75.
Feb 22, 2010 | Texas Instruments TI-30XA Calculator
How to change a fraction to a decimal on a ti 30xa
to change a fraction to decimal on any calculator just press the numbers of the fraction and press either enter or equals.
Oct 28, 2009 | Texas Instruments TI-30XA Calculator
Convert a fraction into decimal
Sep 02, 2009 | Texas Instruments TI-83 Plus Calculator
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Aug 06, 2008 | Computers & Internet
Texas Instruments TI-30XA Calculator Logo
211 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
