Most likely the antenna lead has come unhooked from the back of the radio. AM stations will pick up with the internal working of the radio, but FM stations have to have a working antenna to work. Also make the antenna is tight to the vehicle .
The alternator is most likly the problem. If it was ok before and you had the alternator replaced the problem should be the new alternator. The above answer is if static is your problem. If you can not pick up stations there is a good chance that you have a antenna problem.
Hi , yes is the answer and you will probably pick up more if there are any . You can get very sophisticated motorized antennae that you can operate by moving it in the right direction.
There may be interferences from electrical appliances fridges, TV. Move the radio to some other place. For AM rotate the radio to get the best signal. For FM and SW deploy the telescopic antenna. For SW you may use an external antenna. For SW, to tune in on a station you need to know the broadcast time and the frequency.
Test and confirm if the amplifier is working with an imput source. If the fault is only a loss of FM/AM signals then try and connect an external antennae based on the signal strength in your area to confirm if there is a fault in the radio sectiion. You can conect a set of wires to the FM loop connection and keep it up , if the signal strength is very good it will give you the signal after a search. Memorise, set an external antennae with a proper setting to get the best clarity.
The power cord is the antenna and it should be stretched out straight for best possible reception. You could experiment with re-orienting the Bose, too.
There is a threaded 75-ohm coaxial FM External connector. You could probably get a compatible FM antenna at an electronics store.
Possible that you have a EMI interferance in your circuit or power which carries into the set..Use the set in the battery mode and swtich off all the mains in your house. if this solves, then check on by one the connected appliances which might produce this static. You could also take the set to another location to see if this reduces off . in this case you will have to check if there is a lurking interferance from the power source. I suppose you might not get this faultt with the FM but MW and SW is bound to pick up the static unless the signal is powerful. Please also try to check your external cords, if possible change the location of the antennae. Further any fault on the radio IFT/filters could be considered. Hope my advice helps you . Good day
You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
This way you can switch it on any station to get rid of the static.
You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
how about the antenna this could be the main problem im not a motorcycle expert but radios i do know and if your getting static the antenna which is called the aireal << spell check is not picking up enough signal
I have noticed various changes in my invehicle FM reception as well. There should be a external antenna that came with your car kit. This is precisely for these types of issues. It is designed to run along the windshield inside the car closest to the Cars radio antenna. It should plugin to the bottom of the cradle. Then tune it into a clean FM station (one that has no local station on it) and position the cradle and/or ext. antenna till you get the best reception in your vehicle. It could very well be that the antenna has come has loose on your car stereo backplane. You would probably notice decreased reception on regular AM/FM stations as well though.
Your wifi reception/functionality is a completely different animal and has no bearing on the FM transmitter in the car cradle. When your on wifi your not receiving signal from a sat. anymore just simply streaming internet audio like your computer.
Good luck.
