Question about Carrier Heating & Cooling
I have a CARRIER 51AKP260H. It is shutting off every three hours with the error code 'H8', meaning the condensation pan is full. It is not particularily humid... nor is the pan full. What's wrong with the machine and what do I do to fix it?
  • 19,396 Answers
As you know, when the water tank is full, LCD displays error code H8 and the unit stops.
Under normal conditions you need to empty the water tank and to stop the unit for 3 minutes.
Plug out the power cord before empty the water tank.
Ensure that you unplugget the unit (ur trip circuit breaker) , or the error message won't reset.
If you already did unplug the unit, and you still get the error , then the water level sensor located in the water tank is faulty and must be replaced.
In this case you will need to contact manufacturer, calling the number listed on the owners manual.
In North America, please call 1-800-CARRIER for immediate customer assistance from 8:00a -5:00p (EST) weekdays.
In UK you can contact them at Tel: 0870 600 1155.
Regards
Posted on Jul 22, 2009
What does H8 mean
H8 means the float switch is activated and it is too full of water.
Aug 06, 2015 | Heating & Cooling
What does the message H8 mean?
Call tech support and they can give you all the info you need.
For Technical Support and Warranty Service Please Call (888) 876-5387 Or Write To: Soleus International Inc. 20035 E. Walnut Dr. N. City of Industry, CA 91789 USA www.soleusair.com
Sep 18, 2014 | Soleus LX-140 Portable Air Conditioner
Carrier 38TZA036320 evaporator coil
Hello, sounds like a blocked drain line or cracked condensate pan. Try cleaning the drain line first with a wet/dry vac at the outlet of the 3/4 inch pvc line, if this does not help you will need to have the drain pan repaired or replaced.
Jul 04, 2012 | Heating & Cooling
The drain pan under my unit in the attic is full of water. does this mean the main condensation drain is not working?
Yes!! You need to blow out the drain... usually it is the trap that clogs...
heatman101
Aug 23, 2010 | Carrier Heating & Cooling
I have a direct vent hi efficiency furnace. All
Check the condensate pump if it is full of water and does not come on that will shut the unit down. And might need a new pump. high efficiency furnaces condensate to squeeze the last amount of heat out of the unit. Seen this problem before. But not being there is a little chance that, that is the problem. let me know and we can go from there. okay ken
Jan 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Displaying p2
is there a condensate pan?? do you empty it?
Aug 23, 2009 | Midea MPM-08CR-BB4 Portable Air...
Everstar Model MPK-10CR, What does flashing P2 mean?
p2 means the bottom pan is full, you need to drain the bottom, small valve on the back bottom in the middle
Aug 13, 2009 | Danby DPAC8020 Air Conditioner
Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
Condensate Drain Pan Error E:02
hi there,
have you unplug your a/c unit,this will reprogram back to normal,have your drain basin clean so it will not stored drip water.clean filter evaporator if you have time and know cleaning maintenance of your a/c,it need to be clean specially evaporator fin tube and condenser fin tube,or have it qualified
tech. to clean your a/c to have sufficient cooling effect.have a ncie day dont forget to rate me,thanks a lot
May 26, 2009 | EMI EHW 18000 Air Conditioner
Heating & Cooling Logo
158 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
