Question about Maytag Atlantis MDE7400AY Electric Dryer
How do you pop off the top of the dryer?..is it bolted in any way
How do you pop off the top of the dryer? is it bolted in any way? maytag atlantis
  • 55 Answers
Hello.
Reomve the door from the unit and the plastic peices from the other side in the same spot as the hinges. Remove the front panel. You will see one metal peice on each side that hooks the top on. Remove the screws and the metal hooks. The top will lift up now.
Posted on Jul 23, 2009
How do I take the top off of the Maytag Atlantis dryer?
they are called baffles. and can only be accessed by getting to the outside of the drum. have to remove the body but u may have a bad baffle if the screw hole is busted up?
Sep 14, 2014 | Maytag Atlantis MDE7400AY Electric Dryer
How do you install the belt on a Maytag Atlantis Dryer?
Ya gotta remove the front panel to get to the innards on this beast.
Take the door off. Opposite from the door hinges is 2 more screws that are used to hold the goalpost shaped front panel on there. Once them screws is out the panel pops off and you raise the top after removing the holddown hooks.
Then you gotta remove the front shroud and get the drum out. Give it a good cleaning. Oil the rollers.
Service manual
Nov 08, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
How do I remove the panel to get into the inside of the dryer on the maytag atlantis MDG8400AWW
To remove the front open the door and remove the screws from the door hinge,then remove the screws from the other side as if the door were mounted to that side. Place a putty knife in the seam between the front panel and the cabinet at the upper corners of the front panel and pop the panel off from the retainer clips that are mounted to teh cabinet the top of the panel will become free so ya can pull it off from their.
GENE
Sep 23, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Repair loose tumbler fin
Pop the top, remove the front, the drum will come free. Take pictures of how the belt goes around the motor. Fix your "fin" and reverse.
The top is held down by spring clips.
Thanks for your interest in FixYa.com
a
Dec 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Pop the top off the dryer
Check the door switch. To remove the top there are 2 spring clips or screws located inside door opening going up into the lid. Remove and you will be able to see in side nd check the door switch
Sep 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
The paddle broke off in my Maytag Atlantis Dryer
you need to remove the frt cover 1st and then the screws will be accessible to remove top cover
Sep 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
We have a Maytag Atlantis dryer. Inside the tub
Did you try opening up the back of dryer or the top?
Sep 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Replacing the belt for Maytag Atlantis Dryer Model MDE7600AYW. What steps do I follow ??
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 10, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I HAVE A OLD MAYTAG DRYER 25+YRS AND I CANT GET THE TOP TO POP OFF. ANY SUGESTION ON HOW TO GET IT APART?
If it is that old, look at the bottom of the front panel, about three inches off the floor for a phillips head screw on each side. Remove the screws, swing the front panel up a bit and unhook it from top and set to the side. Now, you can remove the screws holding the top onto the side panels and swing the top back.
Apr 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis Model 6400AEW Dryer bought 2003
On my 2006 Maytag Atlantis the top is held down by 4 screws 2 under the front and 2 on the back.
To remove the 2 on the front you need to remove the screws in the door and remove the door and front panel, than remove the 2 screws. The 2 screws on the back hold a white plastic fastener. After removing the screw, pry the bottom of the plastic fastener with a flat head screwdriver. Than with a very thin screwdriver or a thin pry bar wedge it under the top cover and just pop it off. Take care to not scratch your dryer while prying the plastic piece off.
Good Luck
Jan 11, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
270 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
