SOURCE: Epson scanner V100
Check the calibration strip to make sure it isn't soiled. This can cause streaking in your scans. Also check the glass where the paper is. Make sure it is clean as well.
SOURCE: Scanning multiple page documents
Yes you can. You need a small scan application whitch allows you to scan multipages.
There are for example ScandAll21 from Fujitsu (freeware) or PaperPort 11.
http://www.opendrivers.com/driver/229211/fujitsu-scanners-scandall-21-v4.2.34-windows-free-download.html
http://www.nuance.com/paperport/
SOURCE: I Can't start epson scan software.
My guess is that the cd that you are attempting to use is for a different version of windows than you presently have. If that be the case; download new software and driver for the OS that you now have.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14587&infoType=Overview
SOURCE: Goes through motions of scanning normally, but shows blank page
Epson PERFECTION 1670 AC Adapter driver download
SOURCE: Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
