Question about Gevalia 50041 / 50443 Coffee Maker
Coffee maker stoped working
I recently joined gevalia and the coffee maker which is programable stopped working, it wont heat water tho all the clocks work and programing buttons work it kicks on but then does nothing,i have only been using cofee maker for 3 weeks...no heat comes from burner or to heat water
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
  • Make sure the power supply is all rite (if not try with different socket)
  • If your able to seee light..then try re-programme it using buttons.
  • Still if you face same issue ..i request you to call technician.dont try any thing,Give it to safe hands
  • Thanks
  • Posted on Jul 22, 2009
    Clean it, I used lime out, works perfectly now. about 1/2 cup liquid limeout in about 2 cups water, run it through bout 2 times, be sure to rinse throughly afterward, run several pots of water through. also coffee maker cleaner will work but slower, hope this helps.
    Posted on Sep 09, 2009
    I have a Gevalia Coffee Maker, the programming screen has went out. Is there a fix?
    Hi Tina,it's time for a new and different type of coffee maker,when these Gevalia quit working,their like bic lighters when they get empty,throw it away,there are many complaints about these and their customer service will not help.I researched it for you and this is what I found out.
    Jun 26, 2017 | Gevalia Coffee Makers & Espresso Machines
    Water not heating
    If it's full of water & the red light is on, check if the maker is heating up the warming plate..if not, odds are you may have a bad heating element. Brewing cycle won't start without it.
    Apr 06, 2014 | Gevalia CM-500 12 Cup Coffee Maker
    Gevalia 12 cup coffee maker slow brewing
    The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
    May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
    Our office has a Gevalia Deluxe coffeemaker. It
    Most likely the cycle thermostat that turns off the heating element has failed. It is supposed to reset after the it senses the water temp below 130 deg. If it did not reset or has failed it will not turn on the heating element but the clock will work fine.
    By the time you ship the unit to a repair center with parts and labor and get it returned to you the cost would be as much as a new unit.
    Thanks for using FixYa.
    Kelly
    May 13, 2010 | Gevalia CM-500 12 Cup Coffee Maker
    Xcc-12 gevalia coffee pot wont brew.
    Thermal link open. Located in base of unit mounted against the warming pad heating unit.
    Oct 28, 2009 | Gevalia CM-500 12 Cup Coffee Maker
    Gevalia xcc-12
    clean with limeout, or coffee maker cleaner, I used about 1/2 cup liquid limeout 2 cups water, run through bout 2 times, be sure to run several pots water through after cleaning,
    Apr 25, 2009 | Gevalia 50041 / 50443 Coffee Maker
    Gevalia #XCC-12 Program Mode
    Representatives from Gevalia contacted me and determined the product should be replaced with no cost to me. I expect a new coffeemake within the next week or so. Fantastic customer service - not very common any more.
    Jan 11, 2009 | Gevalia 35411 / 50433 Coffee Maker
    Gevalia 50041 / 50443 Coffee Maker Logo
    466 people viewed this question
    Top Gevalia Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Andrew Taylor
    Andrew Taylor
    Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
