Question about kawasaki Full Suspension Mountain Bike Men
My vulcan 1500 1997 back fire somme time wy
My vulcan 1500 1997 back fire some time wy
    Novelist:
  • 137 Answers
Lean gas mixture. or the valve timing is off, but probably both. A lean mix will run really hot and allow for secondary combustion in the pipes (backfire) when the valves let even a bit of uncombusted gas through. My guess is that the bike hasn't had the carbs cleaned out thoroughly in a while. Run a half can of Sea Foam with your full tank of gas to help clean out the carbs, but really you should take them apart and dip them to clean everything out. Also you could adjust your pilot screw settings to make it run a bit more rich, but then you are just compensating for the dirty carbs. That's just my guess.
Posted on Jul 24, 2009
Could I have a blown fuse on HTC Blu-Ray player?
you have seen first what voltage apply to your device or you have putted in without seeing nothing. if you make this you must change the voltage block in your device which is a transformer a little transformer and somme electronics, somme time when you plug in and the pins cable going in the same time a condenser inside device respond make the voltage too high to administer , this is why power go out in your room, even this have somme blown parts and you have to repair them changing, at least a fuse inside your device
May 10, 2014 | RCA Televison & Video
I have a Vulcan lg400 propane fryer I have used 4 times at outdoor catering events over the last year yesterday while using it it began what I would call backdrafting. could low propane level in bottle...
It sure did. Never use a gas fryer in low gas pressure for a long time for soot will build up inside the fire tubes.
Check and clean fire tubes, make sure that the flue is not restricted and there should be no air entering the flue.
Regards.
Nov 03, 2013 | Vulcan LG400 Deep Fryer
I have a Vulcan lg400 propane fryer it has only been used 4 times for catering events. yesterday we were using it and after a while it started what seemed like mild back drafting the flame was actually...
Hi there. Flames rolling back instead of shooting inside the fire tubes can be a result of clogged fire tubes or air entering the flue, also check if there are objects blocking the flue. Regards.
Nov 03, 2013 | Vulcan 1VK85DF Hi-efficiency Gas Fryer...
I have a 1996 1500 vulcan and it's not firing on the left side, I can smell raw fuel and there is no power, any suggestions please
I've got the same Vulcan. It has 2 coils. If one side is not firing then check the coil that supplies it with power. Easy to check - use a "light" tester and see if it lights up. The coils are underneath the tank / seat.
Apr 01, 2013 | 1996 kawasaki VN 1500 Vulcan Classic
The 750 vulcan will crank 3 times in a roll then flood out
sounds like you need to set the floats in the carbs.
May 25, 2010 | 1993 kawasaki VN 750 Vulcan
Our new Nerf Vulcan EBF-25 won't auto fire. We tried changing the batteries to several sets of new ones, but it still won't work. Any thoughts?
You might have a bad motor in your nerf vulcan. If you want the aouto fire to work than you may have to get a new Vulcan.
Dec 13, 2009 | Nerf Secret Strike As 1
2001 Vulcan 1500 Classic - Started to back fire when you let off the throttle. Has never done this prior.
dear vulcan owner i had the same problem on my 96 vulcan classic found out that the carb is set to lean from the factory solved the problem by rejetting the carb. i also installed a set of aftermarket pipes made a world of diff to the power out put
Mar 30, 2009 | 2001 kawasaki VN 1500 Vulcan Classic
kawasaki Full Suspension Mountain Bike Men Logo
221 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
