My printer got dropped and now it says cover open when it is turned on and won't operate
  • fougzki May 11, 2010
    Did you try to look for something that is mechanical. Usually a switch when you put the cover, it will hit the switch. Or maybe it is stuck up or been displaced that the cover doesn't hit it when you place the flip cover.
  • 41 Answers
Well it is clear that the printer is suffering form a hardware problem ..
so check the things with the local tech
Posted on Jul 22, 2009
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
When opening my printer to get to the cartridges, they are stuck inside the printer and won't move. The on/off button is flashing.
Aug 26, 2011 | Lexmark Z2320 InkJet Printer
My canon MX340 won't print, saying there is a printing error 5200. I tried unplugging the printer and turning it off, but it still won't work
I will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see if that fix the problem.
Jul 11, 2011 | Canon PIXMA MX340 Wireless Office...
Lexmark X85 won't feed paper. When trying to
There could be something in the paper feeder that's blocking the paper path. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
ns Serif"'>6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge.
Jul 11, 2011 | Lexmark X85 All-In-One InkJet Printer
Toner light keeps flashing and printer won't print - even though it has a brand new cartridge.
Please try the following steps.
  1. Turn the printer OFF.
  2. Reseat the cartridge.
  3. Switch the printer ON.
Or
  1. Open the top cover.
  3. Close the top cover.
Jul 02, 2011 | Lexmark E232 Laser Printer
My lexmark printer x 3470 will not operate....it says the cover is open but it does not appear to be and none of the controls will function.... help please??????
It could be due to the cartridges in the carrier or the sensor for the cover has become stuck. Open the printer cover and remove the cartridges from the printer. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and close the cover. Check for any errors.
Jun 15, 2011 | Lexmark C533DN InkJet Printer
I changed my ink but it wont let me print it keeps saying i need to change my ink why?
What is the version of your ink cartridge? It could be that it's not seated properly in the cartridge carrier. Open the printer cover and remove the cartridges. Close the cover. Unplug and replug the printer into the power outlet in the wall to reset it. When the printer turns on, open the printer cover and reinsert one cartridge first. Close the cover. If no error, open the printer cover and reinsert the other cartridge. Replace whichever cartridge is causing the error to appear. You could also try to insert a different known working cartridge to determine if the other is faulty.
May 19, 2011 | Lexmark Z2300 InkJet Printer
How do i change my ink cartridges in my kexmark x3650
Turn the printer on.
Lift the lid that covers the print-head mechanism.
In a few seconds, the print-head will slide to a position from where you can "unlock" and then remove an ink-cartridge.
Apr 10, 2011 | Lexmark X3650 Printer
Printer says there is a paper jam but there is not.
Please double check your printer for paper. Just a little piece of paper left in the printer rollers or out tray will not let the printer operate property.
Oct 01, 2009 | HP PSC 1210 All-In-One InkJet Printer
Juddering
okay TRY THIS: open printer cover (printer unplugged) LOOK FOR A LARGE SILVER BAR THAT THE INK CARTRIGES RIDE ON .
APPLY two or three drops of 3 in 1 oil to the top of this bar close cover and plug back in the wall see if this helps.
Oct 04, 2007 | HP PSC 2175 All-In-One InkJet Printer
k24674
jasbo
jasbo
