Question about Canon Cameras
I recently clean the disk and since then the camera does'nt work well. I can read the pictures but when it's time to take one sometimes i have an image and sometimes all the picture is not really define it's like really cloudy. What can i do to remedy this problem. When it's in reading mode i have no problem. And it does'nt do that all the time. Thank you for your answer.
  • 580 Answers
It may be a result of UV Cannon Makes a UV Haze Protection Filter fits most Canon Lenses and protects the front element of the lens from dirt and scratches while also correcting for Ultraviolet (UV) light which can produce a bluish cast in your images and obscure distant details.
Posted on Jul 22, 2009
Hi, I have the Nikon Coolpix 3000 and I've recently had some problems. I have only had this camera since December; Several times I have tried to upload pictures and "this file contains no image...
You can try to reformat the sd card. Sometimes cards will contain data that disrupts the reading process.
Also, sometimes if you edit images on the pc, such as rotating them in Window's image viewer, it will rewrite the image as a jpeg that is unrecognized in the camera.
Lastly, check to see if the photos are being saved to the sd card or the camera.
Mar 10, 2011 | Nikon Coolpix S3000 Digital Camera
Even if the batteries are fully charged, the camera won't work most of the time. the lens just keep on going in and out and sometimes gets stuck halfway. i can sometimes review pictures but it doesn't...
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Dec 15, 2009 | Canon PowerShot S2 IS Digital Camera
Will not read disk, says crack dirty even brand
HI,,
ITS PRBLEM WITH URS CAMCODER INSIDE READING LENS ,,
SOMETIMES NEW CDS HAVE SOME TRACK READING PROBLEM,
CHECK IT WITH AGAIN A NEW CD.
OR
CLEAN LENS WITH CLEANING SOLUTION OF CAMCODER,
IF BOTH DOESNT WORK ITS PROBLEM WITH URS CAMCODER LENS..
APPROACH TECH..
TNKS
RABBANEES
Nov 11, 2009 | Hitachi DZ-MV730A DVD Camcorder
"No Read" display...99% of the times.
OK. Since the laser cleaning disk could not be read I used a can of air (used for air brushing) and blew air into the disk opening. I thought I might clean any dust that may have collected around any parts that needed to be cleaned. This seemed to have worked. It is also possible that dust accumulated in an area that would not allow the disk to line up properly. This could explain why it worked sometimes. If this continues as a problem I will use the EZ17 only as a tuner for my EZ55.
Oct 01, 2009 | Panasonic DMR-E55 DVD Recorder
Reads CARD FULL, can't view the pics, reads NO IMAGE
Sounds like the card has died. unfortunatly this can happen. and could be caused by a number of things including static.
you can maybe try a disk repair in windows.
hit your windows key and press r at the same time. in the command line type CMD and hit enter, it will open up a DOS window. type CHKDSK ?: /f where teh question mark is, is the drive letter that windows has assigned the card when you insert it. if it is an error that is repairible this might work.
Sep 23, 2009 | Olympus SP-560 UZ Digital Camera
No Pictures but full card
Sometimes when you edit pictures on your memory stick, it will transfer the files to a different folder. Then the card will seem blank to the camera. Format the memory card using the PC to clean it for good.
Nov 12, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Dvd player problem
check your lense condition it may need to be cleaned if there is any dust buildup.
Sep 27, 2007 | Daewoo DV-6T955B DVD Player/VCR
Viewing screen goes all white and mode select flashes on
This seems to be a commonn problem for Sony and has been addressed several times in this forum: http://www.fixya.com/support/t119207-view_finder Please read all the solutions - basically, looks like the problem is with a loose connection and the fixes range from cleaning the contacts to giving a whack to the camera!
May 24, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Windows NT operating system
Your Kodak EasyShare digital camera will not work directly with a computer running the Windows NT operating system. The Windows NT operating system does not support the universal serial bus (USB) standard, and all Kodak EasyShare digital cameras communicate using the USB standard. However, you can transfer pictures from your camera to your computer by purchasing a parallel port card reader. Take the memory card with pictures from the camera, insert the memory card into the card reader, and then copy the pictures from the memory card to the computer.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Cameras Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
