Question about Frigidaire GLTR1670A Front Load Washer
Drum will not spin
Drum will not tumble - water keeps on flowing into the machine and the pump is no at the same time - non stop, if turned on
  • Marcin2 Nov 23, 2007
    Maybe I'll check - but machine has been in the same spot for about 5 yrs.
    President:
  • 1,294 Answers
If your water keeps flowing out, it could be that the pipe behind is not at the correct level, about three feet from ground level; your pump pumps the water out OVER this height. It should not be at ground level.
Posted on Nov 22, 2007
  • prem mathew Nov 30, 2007
    What was the prob. exactly...........would like to know.
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
GE Profile washing machine--- spinning does not stop.
Sounds like the water pump may be faulty. That would keep it from pumping the water out, which might keep it spinning in an attempt to empty the drum of water.
Water pumps are generally accessible from the rear, via an access panel. Check it for debris or a worn bearing. It should be obvious.
Nov 09, 2012 | Kitchen Appliances - Others
Washer fills and empties but won't wash or spin
hello,
If the motor is spinning very rapidly when it should just be tumbling then it sounds like the tacho has gone or come loose on the motor.It may well need a new motor or there could even be a fault with the main programmer
Apr 17, 2010 | Tricity Bendix AW1000W Front Load Washer
My issue: watertank is full, when powered, coffee buttons and the left LED are blinking. When I open the steam valve, the pump works for like 5-10 seconds then stops, neither water nor steam come out. Same...
HI
You have a restriction in your flow meter or inlet opening. Usually it's the flow meter. The flow meter is connected to the intake opening on the back of the machine by a silicone hose. The other hose connected to the flow meter goes to the suction side of the pump. The intake side of the flow meter has a small opening and the other side connected to the pump has a large opening. When the pump turns on and everything is clear, the small side of the flow meter creates a jet of water that spins the turbine. This lets the computer know that water is present and turns the heater on. If the turbine doesn't spin the computer thinks the pump is bad and turns the light on for water and keeps the heater from turning on and burning up. You need to clear the small opening in the flow meter.
Nov 17, 2009 | Saeco Incanto Classic Espresso Machine
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
High speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Mar 23, 2009 | Frigidaire GLTF2940ES Front Load Washer
Short water flow time
If it's new you should call for service. Ask the technician to turn the water level switch set screw so it will stop filling at a higher setpoint rather than stopping at the edge of the gray cylinder baffels.You are aware the factory water level switch is pre set for low level because of water restriction regulations for manufacturers.But that means nothing for me if my laundry is comming out still dirty.. Much later and after much research i turned the water level switch set screw under the lid clockwise a half turn to have my WM0642HW fill up to the lower door seal to tumble in some water.How it was set before resulted in terrible wash performance especially with full loads! Forget it! It was WICK washing instead of tumbling in some water.Since i made the adjustment on the water level sensor the washer is 100% better than before.Trust Me!
Apr 12, 2008 | LG WM0642H Front Load
Won't spin clothes dry... possibly bad wiring??
Casa, make sure your model number starts with 417.43042 otherwise this post is trash. First have your husband drop the bottom panel and check the drain pump for debris, coins, etc. This model will not go into high spin if the pressure switch detects there is water in the tub. There was also a service flash out on this model regarding the timer not advancing. This had to do with electrical noise generated by the opening and closing of the timer contacts. This sent corrupt signals to the motor controller and the washer would stall in cycle. They corrected this problem by adding 3 jumpers to the motor controller. Part 134306000. My feeling is that you have a pump drain issue, but it's hard to tell without being there....Catriver...post back.
Nov 09, 2006 | Kenmore 43042 Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
54 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
