Question about Rockford Fosgate Power 1500BD Car Audio Amplifier
Wiring diagram i have three 15" 4ohm dual voice coil subs that i want to hook up to my 3200watt hifonics colossus amp. i would like to know the best way to hook them up with out my amp getting hot or my clip lights flashing while producing as much power as possible. and also do have to bridge the amp??
  • damienweekly Jul 22, 2009
    its a 2 channel d-class mono amp 3200 watts hifonics colossus xxv
  • jephead May 11, 2010
    is it the 2 channel or mono ? - what is the model number of the amp ?
X2: wire all subs in series, then parallel them together, that should gv u 8 Ohms per sub divided by 3 for a total resistance of 2.33 Ohms. Run the amp in bridged/mono configuration for max power output. The amp should handle this load without overheating! Verify that the amp can handle the 2 Ohm load in bridged mode.
Posted on Apr 22, 2016
Diagram 1500bd
Posted on Sep 03, 2011
    Problem Solver:
  • 11 Answers
Run them in sereis hooking them all up together and bridging the amp
Posted on Jul 22, 2009
How to hook up 2Infininity dual voice coil speakers with coils and speakers wired in parallel to a Hifonics BRZ1200.1D 1200 watt super D-Class amplifier?
Wiring the voice coils and speakers both in parallel like this:
http://imgur.com/furO9yh
will be stable at 1 ohm mono.
Wiring the voice coils in series and the speakers in parallel like this:
http://imgur.com/jHSvmVU
Will be stable at 1, 2 or 4 ohms mono
I'm guessing ur subs are 4ohms by the way
Jan 23, 2015 | Dual Car Audio & Video
Hifonics colossus-ltd dual monoblock amp does not have much output, running a cerwin vega stroker dual 2 ohm sub wired 4 ohm load bridged
Bridge at 4ohms your only getting 600watts rms. You will need to bridge at 1ohm (parallel) and adjust the gain accordingly. This will give it 1600 watts rms. If you would of had a dual 4ohm sub, then you could of bridged it at 2ohms mono, but you can't you have to go either 1 ohm or 4ohm. I believe it's not getting enough power.
May 20, 2012 | Hifonics Colossus-ltd Dual Monoblock 3200w...
What's the best way to hook up 2 Hifonics hdl12d4 subwoofers to a mono amp
Ok, your post has two different models listed. Let's start with something you need to know about your amplifier. Is it one ohm or two ohm stable. This will make a difference. Also, whether your subs are single voicecoil (HFI12s4) or dual voice coil (HDI12d4).
Let's start with the easy scenario. Let's say your amp is two ohm stable and you have two single voice coil subs. It's simple. You go from the positive of the amp to the positive of both subs and the negative of the amp to the negative of both subs. This will provide a 2 ohm load to the amplifier, thus pulling all the power out of it.
Unfortunatley, if you have two dual voice coil subs, you won't be as efficient. You will only have the options of a 4 ohm load or a 1 ohm load.
This is where having a one ohm stable amp would come in handy. If the amp is one ohm stable, hook the positive of the amp to all 4 of the positives on the subs, and hook the negative of the amp to all 4 negatives of the subs. This produces a 1 ohm load.
WARNING!! If you have a 2 ohm stable amp DO NOT use the last wiring scenario. It will fry your amp.
Now, the last is a little trickier. This is for two dual 4 ohm subs. Follow closely. Hook the positive of the amp to one of the positives of each sub. (do the next step to both subs) Go from the negative of the voice coil that you hooked positive from the amp is hooked to, and hook that to the positive of the unused voice coil. Then go from the negative of that voice coil and hook to the negative of the amp. Make sure this is done on both subs. This will give you a 4 ohm load.
Hope this helps
Aug 31, 2011 | Hifonics HFI 12S4 12 DVC Subwoofer 600...
I just needed some help with wiring my p8002 rockford amp to 2 fosgate 10 inch subs i just bought. there 4 ohms a piece and dual voice coil. i dont know much about car stereos but people keep telling me...
Well i tried looking up that amp, but Fosgate sight is down. So assuming that the best power out of your amp is 2ohms off the bridged hookup, and the subs are 4 ohms per coil, the best way is to only use one side of each speaker and hook it straight the the bridge. Only using one hook up wont hurt anything, its just for giving you wiring options. And when adding up ohms of speakers, it goes like this. If you had two 4 ohm subs, that'll give you a 2 ohm load. If you hooked up all your hookups, it would be like having four 4 ohm subs, and would give you a 1 ohm load.
Jan 19, 2011 | Car Audio & Video
How to wire post to post for 1subwoofer audiobahn aw1200n
depends on how you're hooking them up to the amp, and what type of amp it is you are using. but to wire them parallel, and drop the ohm rating, assuming it's a dual voice coil sub, you wire - to + on the sub, then - to the - on the amp, and + to + on the amp. Here's a diagram:ae0c628.jpg
Oct 07, 2009 | AudioBahn AW1200 Car Subwoofer
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
Sep 07, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
Hook up my 2 sub and my 2 amp
wire the subs at 2 ohm each. red to red and black to black and then to the amp. if thay are a dual 4 ohm sub. dual 2 ohms will need to be wired red to black on one coil and the other conected to the amp.
Apr 09, 2009 | Danby DDR601 Dehumidifier
Kicker l7
hook them up parellel for 1ohm load
Nov 23, 2008 | Car Audio & Video
Dual voice coil wiring to class d amp
The easiest way to think of wiring voice coils and subs is this:
  • Two items of the same impedance in parallel = Half of the impedance
    • 4 ohms in parallel with 4 ohms = 2 ohms
    • 8 ohms in parallel with 8 ohms = 4 ohms
  • Two items of the same impedance in series = Double the impedance
    • 4 ohms in series with 4 ohms = 8 ohms
    • 8 ohms in series with 8 ohms = 16 ohms
In this case, you want to wire two subs, each with dual 4 ohms voice coils, so that the total equals 2 ohms. Your options are:
  • DVCs in parallel, 2 subs in series = 4 ohms
  • DVCs in series, 2 subs in parallel = 4 ohms
  • DVCs in parallel, 1 sub = 2 ohms
With two, dual 4 ohm subs, you can only have 1 ohm or 4 ohm total impedance.
Mar 16, 2008 | Car Audio & Video
Rockford Fosgate Power 1500BD Car Audio Amplifier Logo
486 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Tygh Duval
Tygh Duval
Professor_V
Professor_V
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
