Question about Magic Microwave Ovens
I have a majic cheif 1000w microwave. after heating up dinner it just shut down no power, and no display. I checked the fuse behind the touch panel, it was ok. I put it back togather, plugged it in and it started working again. Any ideas??
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Might be some issue with sensor,so it shuts down automatically.Since its happening for first time.If you come across this problem again..please post your issue...we will help you to fix that
Posted on Jul 22, 2009
Amana microwave reset button?
Does the power panel have anything on it?? If not. it probably has a burnt fuse inside the unit, one year old should have a warranty on it Check out places that work on microwaves.
Mar 05, 2015 | Amana Commercial Microwave RMS10TS Touch...
My microwave shows nothing on display and will not turn on
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 27, 2012 | Maytag Appliances Over-the-Range Microwave...
No power cannot turn on
Inside the unit behind the control pannel is a ceramic fuse looks like a car glass type fuse. To replace it you must remove the outer shell. First unplug the device,2nd
place on a flat work area,3rd remove the screws from the back of the unit,4th pull the outer shell back if it's stock a flathead screwdriver can be used to aid in removal,5th after removal look behinde the control pannel find the main power wires by following them from the back of the unit the fuse will be about 1" long and about as big around as a #2 pencil remove it carefully and replace it with a new ceramic fuse. The fuses are about $3.00
If you don't feel comfortable doing this yourself find a repair shop it will cost about $35 dollars
Hope this helps
Please leave feedback
Jan 07, 2010 | Kenmore 63672 Convection/Microwave Oven
How do i change the heating fuse for a ge spacemaker microwave
unplug first, take three screws out of top vent cover and there may even be some on the top cabinet holding vent cover on front, then you might see fuse holder just behind vent cover, if not remove screw(s) holding touch pad on, then slide touch panel up and out. it will rest on hinge, then you should see fuse holder inside behind touch panel. BE SURE TO UNPLUG FIRST AS ELECTRICITY CAL KILL YOU.
Oct 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No display on microwave touchpad for ge Model JKP62G
The GE JKP62G Microwave / Oven combination has an internal fuse behind the control panel for the microwave. The oven will operate but the microwave will be totally dead (no light, no clock). Turn off the breaker for the oven at the fuse box (30 Amp double breaker). In order to replace the fuse you will have to open the door to the microwave, remove the two screws (Torx) from the front control panel (located on the left edge of the control panel), wiggle the panel to the left (there are two metal tabs that stick into the metal frame of the microwave on the right of the panel) and then tilt the panel down from the top. There is a metal bracket that holds the control panel to the microwave at the bottom (don't remove it). Look towards the top of the microwave inside the area behind the control panel and you will see a 15 Amp screw in fuse. Replace the fuse and that should fix your problem.
Apr 15, 2009 | Microwave Ovens
Microwave not heating items
if it is fuse then there should be no lights or display at all. if there is, then it is not a fuse. it could be the magnetron.
the fuse is located inside the microwave. you have to bring it down and open the cover.
i hope i was able to help
pls rate me..
tnx ,
drcool
Jul 19, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
GH7145XFB microwave hood
There is an internal fuse, and also a couple of thermostats, and I would be suspicious of the thermostat on or near the magnetron.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It helps with troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 14, 2007 | Whirlpool GH7145XF Microwave Oven
Maytag MMV5165BA Over The Range Microwave
We had this problem. It was installed improperly - to recirculate instead of to vent.
Sep 07, 2007 | Westinghouse WST3504 Microwave Oven
Bosch hmt9626 gb 1000w microwave cuts out after 20secs
ur mag netron is faulty the reason for cutting out is thermal cutout switch change magnetron
Jan 20, 2007 | Bosch HMT9626GB Microwave Oven
Microwave Ovens Logo
51 people viewed this question
Top Magic Microwave Ovens Experts
William Miller
William Miller
Steve
Are you a Magic Microwave Oven Expert? Answer questions, earn points and help others
