Canon MP600, The error says, The paper is jammed. Clear the paper and press okay. I have cleared the paper put the error won't clear to enable me to print
    President:
  • 1,197 Answers
Check for Obstructions in the Auto Sheet Feeder (ASF) If paper does not reach the Paper Edge Sensor, the LCD will show [LOAD PAPER].
  1. Power off the printer.
  2. Remove paper from the (ASF).
  3. Look in the ASF area for an obstruction. If there is any foreign material (such as a piece of metal or pen) inside the printer, after turning the printer off and removing the power cord from the outlet, remove the foreign material by hand, or with tweezers.
  • 5. Open the scanning unit (printer cover) and confirm that there is no foreign material in the printer. If there is any foreign material, remove it.
    Note:
    Avoid touching inner parts.
    1. Close the scanning unit (printer cover).
      Note:
      When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. Power on the printer and confirm that the printer operates normally.
    also
    Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary.
    1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
    2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for here additional information.
    3. Press the <HOME> (A) button.
      Canon MP600, The error says, - 8c26bdd.jpgttp://i.fixya.net/uploads/images/8c26bdd.jpg" alt="8c26bdd.jpg" class="h_mi" />
    4. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Settings], then press the <OK> button.
    5. Use the Easy-Scroll Wheel (B) or press the right / left arrow to select [Maintenance], then press <OK>.
    6. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], theCanon MP600, The error says, - 335d028.jpg;OK>.
    7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
    8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2.
    9. Use the Easy-Scroll Wheel (B) or press the up / down arrow to select [Roller cleaning], then press <OK>.
      Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
      Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
      if all the above mentioned procedures doest solve ur problem.... u either have a broken roller or a broken sensor.... it needs to be replaced by contacting canon....
      thank you for using Fixya
      have a nice day and good luck
    Posted on Jul 22, 2009
    Error message: Paper output slot - the paper is jammed. Clear paper and press ok. (I really dont think any paper stuck but how do i get into back of printer to find out)
    Says I have paper jam but I don't have paper in there also I went and bought ink and put it in the light went out of paper jam but when I went ot use it it came back on.
    Feb 09, 2010 | Canon PIXMA MP600 all-In-One InkJet...
    My Canon Pixma MP600 printer has an error coming up of 6A00
    Hi
    Error 6A00
    The 6A00 is a Canon generic code for paper path jam.
    Solution 1:
    Move the printhead carriage back and forth a few times.
    Solution 2:
    Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
    Solution 3:
    Press the ink pads down in the purge unit.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Jan 29, 2010 | Canon Pixma MP600 Printer
    Error paper output slot. the paper is jammed clear
    Try this...With te printer off line, press the paper feed button making sure thre is paper in both feed trays. Once it print, a blank page go in and change back t your desired papper source. Hope that helps, please let me know.
    Ash
    Jan 27, 2010 | Canon PIXMA MP600 all-In-One InkJet...
    Cannon Mp600. I have an error code 6A00
    Try
    Solution 1:
    Solution 2:
    Solution 3:
    Jan 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
    It thinks it is jammed when it is not
    there has to be a tiny piece of paper stuck in there some where. It can be a very small piece. Check again, use a flash light if you have to, to get a really good view.
    Nov 20, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Canon mp600 printer error code 6A00
    Heello there
    Error 6A00
    Solution 1:
    Solution 2:
    Solution 3:
    Nov 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
    Paper jam
    Remove the paper following the procedure below.
    (1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
    Do not load it in the landscape orientation.
    (2) Turn off the machine.
    (3) Turn on the machine.
    The paper is fed and then pushes out the jammed paper as it ejects.
    If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
    James Mac
    Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
    My canon MP600 PRINTER
    There's a couple things you can try:
    First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
    Double check that your ink tanks are seated right too
    If you STILL have the error code, try these two types of resets:
    To clear the memory:
    1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    2. Wait approximately ten seconds and then press the <ON/OFF> button again.
    3. Wait until the device has completed its cycling process before submitting another job request.
    To do a stop/reset:
    To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
    1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
    2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
    If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
    Good Luck!
    Maggie B
    Feb 23, 2008 | Canon PIXMA MP600 all-In-One InkJet...
    Computers & Internet Logo
    David Payne
    David Payne
