Question about Canon Office Equipment & Supplies
Showing change paper size when select LGL size paper in canon ir2016
  • 149 Answers
If you are selecting legal on the screen to copy, then be sure that you have legal paper in the tray for printing and that any tray guides are properly set to reflect this.
Posted on Jul 25, 2009
Canon ir 2530i says load paper when we have enough papers. orange light keeps blinking on top
Hi, restart your machine and check in the touch panel, in the paper selection tab, if your printer detect the size of the paper (LTR, LGL, etc) if it does, the problem is located in the paper elevation mechanism
Apr 10, 2018 | Canon Office Equipment & Supplies
Cannot print Legal size on Canon IR2420L
LEGAL SIZE IS LGL THAT MEANING 8.5/14 INCH. IF YOU WANT TO PRINT CHECK THE SIZE OF THE PAPER, FLSC IS EQUAL TO 8.5/13
Apr 22, 2014 | Canon Office Equipment & Supplies
I need to change our Canon IR2016 from A4 to A3, Also I need to activate 1 to double sided copies. I am looking on line for the user manual for the IR2016 but can't find
ir2016 is allready A3 size copier.you can change tray setting.pull out tray from machine and then set A3 paper on it according to paper you must change blue lever position from A4 to A3.then close your tray.now you can work with A3 size paper
for double side copying you must be installed a "duplex unit" which is not come with standard machine.It is an optional unit.after that you can make double sided copying.
Jan 19, 2011 | Office Equipment & Supplies
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
I cant copy legal size
Be sure to set Paper Size to LGL (14 inches long)/FLSP (13 inches long).
Additional Function > Common Settings > Reg Paper Size > Drawer 1 > Select right paper size
Jan 25, 2010 | Canon imageRUNNER 1023iF Black and White...
Canon ImageRunner 2270 copier - how can I change the paper select
There is a blue papersize sellector in the paper cassette with an arrow on it,just move that sellector untill the 11/17 mark.change the paper stops inside the tray to the correct possition and the machine will display the correct paper size option.
Jun 18, 2009 | Canon imageRUNNER 2270 Copier
I am using a fax machine Canon L80 and waiting to receive a fax ... it's blinking between and says "received in memory" and "check paper size" ... not sure what to do.
"Check paper size" means that the paper in the machine doesn't match the size selected in the setup.
To change the paper size:
1. Press the Function button.
2. Press the Data Registration button.
3. Press Set button.
4. Use up or down arrows until you see PRINTER SETTINGS.
5. Press Set button.
6. Use up or down arrows until you see PAPER SIZE.
7. Press Set button.
8. Use up or down arrows until you see type of paper in the paper tray (LTR, LGL, A4).
9. Press Set button.
10. Press Stop/Reset button.
Machine should now print out the fax that was received in memory.
Jun 20, 2008 | Canon Office Equipment & Supplies
851 people viewed this question
old marine
old marine
