My W123 machine programmer keeps going round
Please can someone help me with this matter as my machine programmer keeps going round and round. It won't stop. It sometimes makes louds noises when doing a cycle.
  • 221 Answers
Unfortunately you'll have to replace the dial unit, or we can try to repair the dial gearbox. But you'll need some mechanical skills for that.
Update me about your decision and progress
Posted on Jul 25, 2009
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
I have a indesit w123 and when i put it on it starts to fill up and then the dial keeps going round, can you help please...
try and clear prog memory .what to do is set prog knob to an off position where the black spot is then switch on machine the red light will flash quickly then slow down. when it does switch machine off then select program and switch on and it should be ok.if not it could well be a main fault on pcb .indesit boards are not very good .hope this helps.
Jun 07, 2011 | Indesit W 123 Front Load Washer
Dial keeps rotating
This a common problem with Indesit washers..
It is not a timer but a programme selector switch.
What you need to do is the following.
Switch the m/c on, let the drain pump empty the water, then switch the m/c off.
set the selector switch to one of the black dots on the dial, which is stop/reset.
Then switch washer back on, if the dial still keeps going round and round, then you are going to have to call an engineer, as you have what is called an Anomaly (fault).
Plz leave feedback for this solution.
Thanks
Dec 09, 2008 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Ariston A 1635 Margherita washing machine, programme switch keeps clicking
Try Cleaning your filter under the front of the washer it probably has coins and other wonderfull stuff which can cause the clicking issue.
Regards Ed
Jul 06, 2008 | Ariston Technologies AW149NA Washer
Faulty washing machine w123
does the water empty from the machine? if not you will more than likely have something trapped in the pump. the best thing to do is run the grey outlet hose into a bucket, this will empty the machine. then tilt machine back (make sure it wont fall) then remove the plastic kick plate on the front bottom, behind this you should see the round plastic filter this will unscrew and pull out, you may need a couple of towels put on the floor as there is usually water left in the pipes. clean any debris and screw filter back in, should only need to be hand tight. replace kick plate and then give it try.
hope this helps
kj
REMEMBER MAKE SURE POWER IS OFF BEFORE CARRYING OUT ANY WORK.
Nov 09, 2007 | Indesit W 123 Front Load Washer
Indesit w123
the holes above the drawer may be blocked. remove the drawer and scrub the holes with a stiff washing up brush rinse away then try again.
Jun 21, 2007 | Indesit W 123 Front Load Washer
Indesit W123 s UK water overflows from the detergent draw
My machine clicked round, although I did not have the water overflow. I managed to unlock the pump filter, on the front of the machine under the lower panel. This was fiddly. I removed a coin. The machine worked again, but two cycles later starting clicking round the timer. I called an engineer - it worked when he was here, he checked the element and pump and said it was OK. When he had gone, it clicked round the timer again! He came again, and once again it worked perfectly when he was here. Eventually I checked the pump filter again, and removed another two coins. At the moment - it is working!
Oct 11, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
184 people viewed this question
Top Washing Machines Experts
