Question about Weather King 10AJA6001AH Air Conditioner
Central AC unit replaced breaker trips after running 20min
Just had the central unit replaced after running about twenty 20minutes the breaker trips. Cutler Hammer 30 amp circuit breaker does not appear to be hot or blown, will reset be trips after about 20 minutes.
  • rdecampli Jul 22, 2009
    Thanks can a home owner check this or do I need a a/c tech? How do you check? It's a new unit just put in this year.
  • 396 Answers
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Posted on Jul 22, 2009
  • ltworkman Jul 27, 2009
    I would contact the individual who installed, the compressor is acting up causing an overload wich trips the breaker.
Why wont the top 30 amp breaker won't reset?
YES!
New breaker is cheaper than a service call and quicker than tearing the dryer apart.
Jul 10, 2014 | Cutler Hammer Bq Circuit Breaker Bq230240...
What voltage and amperage is required to trip a shunt trip unit
The circuit breaker will have a shunt trip voltage & current ratings, a variable current selector knob, etc. - based on the type breaker (Catelog number). Here is a link to images of C-H shunt trip devices and circuit breakers
cutler hammer shunt trip circuit breakers parts Google Search If you can provide the catelog or model number - I 'll be able to provide add'l help.
Mar 11, 2014 | Eaton Electrical Supplies
Ge circuit breaker tripping
1. Replace breaker (quick & cheap) ... they do go bad.
2. Find the short.
Jan 11, 2014 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Cutler Hammer 15 amp circuit breaker keeps tripping
No - because this will cause the electrical wiring to overheat which could cause a house fire.
This may be helpful:
Basic House Wiring Circuits and Breakers
If a circuit is over loading then it may be because there are too many devices on the circuit which could be solved by removing some of the load, or an additional circuit may be installed for specific devices, such as a microwave oven etc..
Jun 29, 2012 | Cutler Hammer Electrical Supplies
Arc fault breaker trips when you turn florescent and can lights on
Sounds like something is wrong with the light check the wiring. Unhook the light and try ther breaker if breaker does not trip then problem is in the circuit.
Jul 24, 2011 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
Our circuit breakers keep tripping. The house is only 12 months old and our electrician says the builder installed Cutler Hammer Combination type AFCI is the problem. Is there a problem with these being...
They can be defective, but usually not. It is usually something that is plugged in that will not operate on the arc fault circuit. Brush type motors are bad as they are actually arcing at times. Unplug all devices, and try to find the culprit. These are for your safety, and once you find the problem devices you should be fine.
Sep 09, 2010 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
How to reset Cutler Hammer 1 pole 15 Amp
Turn handle to off position and then back on. Same as any other breaker. The red test button can be pressed which will trip breaker. If it trips immediately,unplug all devices on circuit and try to reset. Reconnect each device and see which trips breaker. If this goes to outdoor receptacle, check behind cover for moisture.
May 25, 2010 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Breaker trips when running a small dehumidifier alone on circuit
the breaker is getting weak and won't hold the load, assuming that nothing else is on the line. if it trips immediately u could have a short.
Jul 11, 2009 | Cutler Hammer BR120AF BREAKER CIRCUIT BR 1...
Need wiring info for cutler hammer C25DND330 30amp fire shunt breaker...need to shunt 4/220's and 1/110 can you help
Probably easier and about the same price to just buy a shunt trip main breaker. IIRC, code usually requires that anyway.
As far as the c25dnd330, it's just a regular 3 pole contactor, each pole is good for 30 amps. The three poles are L1,2,&3>>>T1,2,&3. The other two contacts are the control coil. I believe your model is 120 volt (most are)....the voltage should be stamped somewhere near the contacts.
Jan 29, 2009 | Cutler Hammer Cutler-Hammer No.BR48L125RP...
Weather King 10AJA6001AH Air Conditioner Logo
636 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
