Question about Electronics - Others
USB key not recognized
I have a USB key that used to work in my main machine, and now when I plug it in, the computer doesn't seem to recognize it. But, if I plug it into another machine it works fine. Why?? Is there anything I can do to correct this??
    Problem Solver:
  • 17 Answers
Check if you have the motherboard cd. If you have check for usb drivers and install them.
Then try doing the steps below if you dont have the driver cd or if does not work
navigate to
start>control panel>system>hardware>device manager
Run the computer in Safe Mode.
You go into device manager
You select a USB controller, right click, select delete.
You do this for each controller.
Shut down the computer.
Start up computer.
The drivers will load or reinstall themselves automatically. You will see the progress of the reinstallation on the task bar.
Posted on Jul 22, 2009
Need to be able to connect to my computer . plugged it in but computer does not recognize the mouse . red light is on
My computer doesn't recognize my mouse and its not listed in ...
www.tomshardware.com > ... > Windows 2000/NT
Tom's Hardware Guide
Mar 25, 2012 - 9 posts - ‎7 authors
please help.....I am using my keyboard to move my mouse keys and it really sucks. After a storm everything came out fine on my diagnostic ... My computer doesn\'t recognize my mouse and its not ...
Feb 28, 2013
Mylaptop doesnt recognize the usb for my mouse ...
Jan 27, 2013
Computer won't recognize keyboard or mouse - Mice ...
Aug 27, 2012
Computer won't recognize keyboard or mouse? [Solved ...
Aug 6, 2011
More results from www.tomshardware.com
Mouse doesn't work in any USB port - Tom's Hardware
Jan 21, 2016 | Onn Optical Mouse
ASUS USB BT211 Not Working
https://www.asus.com/Networking/USBBT211_Mini_Bluetooth_Dongle/HelpDesk_Download/
Remove the BT211 module. Install the drivers that can be downloaded from the link above. Shut down the computer. Plug in BT211 and turn on machine. The unit should be recognized and drives put in place to make everything work for you.
Semper Fi,
Z
Apr 28, 2017 | ASUS N73SV PC Notebook
IPhoto stopped recognizing my camera. iPhoto was working until yesterday and now it doesn't. Image capture recognizes the camera but does not give the option to import. The USB port works. The hard...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto.
Sep 30, 2011 | Panasonic Lumix DMC-FX3 Digital Camera
Why won't my computer recognize my removable device
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
May 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I am having a problem with my computer (e-machines T5082). I does not recognize any devices plugged into the USB ports. Printer, cameras, Zune, ect. They have power because my speakers draw power from a...
Greetings....
Please try to check if your USB port both rear and front USB port are not defective. Most common problem of defective usb ports are when plug your usb devices it won't recognize the device you inserted. So to make sure that your USB Ports are not the main cause why your computer won't recognize devices you inserted.
Nov 03, 2009 | E-Machines T5082 PC Desktop
USB Memory Key not Recognized on Desktop running Windows Vista
check the formats of the keys. if they are NTFS they might not be recognized by earlier Windows versions. What version of windows does the laptop computer use? It may be as simple as using the correct formatting (FAT or FAT32) on the USB memory key.
Sep 14, 2009 | Maxtor Hard Drive
E machine wont recognize the moniter or keyboard
With the limited info that you provided, it seems like the motherboard is not functioning. When you turn the computer on, does anything happen in the box?
Jul 17, 2009 | Computers & Internet
Electronics - Others Logo
170 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
