Question about Samsung J700 Cellular Phone
Am using a samsung J 700 but i have limited services due to net
This is due to network problem with my phone.i need help
Limited service
"Limited Service" does come up at times on mobile phones and this is due to a limited signal. Sometimes switching off and taking out your SIM card carefully and a soft wipe can resolve other glitches.
But, if the problem continues, try using another sim of different network. if the phone still says limited service, then, it means this is a software problem. You will have to flash the phone for it to come back to normal.
Flashing means you want to reinstall the software on the phone and this will erase all the contact, messages, audio and video file you have on the phone. This done using cables software and computer.
You can take it back to samsung mobile office if it is on warranty.
Thanks.
Jun 16, 2011 | Samsung SGH-i560 Cellular Phone
My cell phone samsung j 700 is limited serviced
if your phone is showing limited service on all sim sards that mean you have to change PA and antenna switch.
you can also try to full reset the phone by entering *2767*3855# sometime it will remove limited service.
PS: you will loose all your data after resetting.
May 17, 2011 | Samsung J700 Cellular Phone
How do i unlock samsung j700 if it is saying limited services
it may be due to network lock, contact service provider if it locked , you can get unlock codes here http://www.mobile-unlocker.com/samsung-j700/rs2wp9/ you need to specify the country and network provider
Dec 10, 2010 | Samsung J700 Cellular Phone
Problem in SGH X620, NO imei, Limited service
problem in sgh x620 ,no imei ,limited service
Jul 02, 2009 | Samsung SGH-G600 Cellular Phone
My samsung sgh-j 700 ask limited service
Well i have the same problem and i also have a SGH-J700 and i have 2 sim cards that has no servise. I tried doing something, using this code (*2767*2878#) or (*2767*3855#) nothing worked but i want u to try it with your simcard in and out if it does not work go to this wap site(http://wwwgsmhosting.com/vbb/member.php?... if it does not work buy a new sim card.
Jun 25, 2009 | Samsung J700 Cellular Phone
Limited Services on my Samsung SGH-D840
i made a couple of calls and it turned out my phone needed flashing to reset all factory and network settings. i took it to a specialist and it cost £20
i'm sure the software to do this yourself is on the NET and you only need the phones USB fire wire to connect it.
Nov 27, 2008 | Samsung SGH-D840 Smartphone
Network problem
hello there....well its quite simple...the network in your area is weak...if you try to use it in city center it should work there ...
if its not working anywhere call the customer service of you network provider...problem could be with your sim ...they can send you sim updates or a new sim and that should be free with in one or two days by post
before calling them check the network connectivity with people living in and around your house or your family and friends ...if they use a different service provider it could be a problem with your network provider
so switch your network ...but before you change just call them such problem can result due to repairs related to cell towers or servers
Hope this help
Cheers
Aug 02, 2008 | Samsung SGH-E900 Cellular Phone
Limited service
Hiya... Go in to tools/ menu settings.. select network services ... tick/click search all all networks. Turn off the phone, restart.... should eliminate your problem
Regards Faggly
Mar 24, 2008 | Lands Phones
Limited servive on screen
go into your menu/settings/network/band
Dec 07, 2007 | Samsung SGH-D900 Cellular Phone
Samsung e250 limited service
this is a common problem with the e250. All you have to do it get a s/w upgrade for the phone from the nearest samsung customer service.
Nov 22, 2007 | Samsung SGH-D900 Cellular Phone
Samsung J700 Cellular Phone Logo
155 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
