Question about Acer Aspire M1201 Athlon X2 320 Gb PC Desktop
Cd-r dvd i have probleem because i my disc don't work
    Scholar:
  • 62 Answers
1. If the CD/DVD drive tray not open.
Open "My computer" windows and select the CD drive . "Right click" onthe CD drive.You will get a pop up windows with the "Eject" option.
If it open that's means the power supply is ok
2. If the DVD drive is not showing on my computer windows or the DVD is not detect the CD/DVD disk
To fix the problem we need to delete the UpperFilters and LowerFiltersregistry key for more details about the troubleshooting step please follow the below link.
No longer access the CD drive or the DVD drive
3. After follow the above steps if you still face the same problem then need to contact the local hardware vendor.
Posted on Jul 22, 2009
When i insert a CD, it won't accept it, "disc error" appears. What is the solutions.
hello there soenensistva
Well first of all Compact discs are easy to be read by a DVD player then ordinary Cd player cause of their lens are made for more compressed Data discs..there for try some of the options
1. make sure that the disc Surface is Clean and don't have finger prints or any other material that is disturbing the the read process between the CD and lens present inside CD player
2.if your CD is precious for you ( that consist some important Data you may need ) then try a DVD player for that
3.if both things doesn't work try a cleaning Cd for Cleaning the Head of CD player .
i wish that your problem may be solved
Best Regards
Oct 15, 2012 | NAD T550 DVD Player
I already wrote disc but how to overwrite a disc
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
How do I format a dvd disc
You don't have to. DVD's and CD's are already formatted from factory. But if you are having problems to record on (burn) them probably your computer is not capable for DVD burn, just CD's. But if it is equipped for burning then try this:
See alsoFormat a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
Nov 30, 2011 | HP Computers & Internet
I have an advent DV1418A and my built in dvd player wont work when i put a CLEAN WORKING disc in it says loading then it says "no disc" please help!
The READ head is dirty or damaged...very difficult to get to the back of TV to disassemble DVD player.. clean read (light diode) head with light cleaning fulid or don't take apart & use official cleaning DVD disc. Look on web site for CD\dvd cleaning disc.It looks like a CD but has 'fuzz' or a very thin " rug" on 'read' side of disc.
Aug 08, 2011 | Recoton Advent Advent DV1418A 14 in....
When I insert a dvd in the slot it does not read the dvd however cd is displayed. What may be the reason?
-cd corrupted ( try clean the disc with cleaner. If you don't have it then try using perfume(with alcohol). I'm also have try many time using my BOSS perfume. Is alright.
-dvd player have problem( try clean with cd cleaner )
-disc dvd is empty (or damage). Right click to DVD ROM .Choose properties, and see what capacity for that dvd. If it have zero use and full capacity is not zero, that mean dvd disc that is still zero.
May 27, 2011 | Acer (KV.16X04.007) DVD Drive
My phillips HTS3105/98 shows "no
The laser disc reader has failed. This could be caused by multiple things, most likely its not worth the repair however there are facilities that specialize in this. I would assume maybe try to sell it and go buy a new DVD player.
May 04, 2011 | Audio Players & Recorders
Now whith any CD say NO DISC
The lens that reads the DVDs might need cleaning or it failed already.
If this is something you want to try, open the DVD cover and open the DVD mechanism, once you do this; you will see something like an eye. Use a cotton swab and rubbing alcohol should work.
If after cleaning it, still does not work; the lens is defective and will need to be replace.
Hope this helps.
Apr 15, 2008 | Apex Digital MD-100 Portable DVD Player...
Pioneer dvd-rw dvr-k17 problem
This worked: thanks to riozebratubo
delete the entires in regedit.exe
"UpperFilters"
"LowerFilters"
They're inside:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}]
-uninstall the driver
- restart
Vista is searching for existing drivers -> done
Feb 05, 2008 | Pioneer DVR-107D DVD±RW Burner
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Unknown cd
This could be a case of one specific bad disc or If this is a non original CD(Burned CD/DVD) some DVD players don?t support burned media If it?s happening with all you?re Cd\s DVD\s It could be a problem of dirty lance In this case a CD lance cleaner could solve the problem
Jan 18, 2006 | Jensen VM9410 Car DVD Player
Acer Aspire M1201 Athlon X2 320 Gb  PC Desktop Logo
234 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
