SOURCE: KM-3035 scanning issues
the 30/40/5035 series machines have two network cards in them. One for printing and one for scanning. and they have separate IP numbers also. make sure you have scanfile utility running on your pc or wherever you are sending the files and the folder set up in the utility. then set it up on the scanner network card.. Not the printer.
SOURCE: Kyocera Km-3035 Locked in cardstock
press default setting/counter button
press bypass setting
press paper type
SOURCE: What is the code for KM-3035 printer's scanner network card?
The print board is a separate board with a different IP address to the scan board. If you just want to ONLY scan the NS-30 scan card is still available separately. Check Ali Express seller China Good Kyocera Parts Shop Code is 1503JR8KS0. It suits a variety of models from KM-3035 through KM-1650, KM-2050, KM-2630D, KM-6030, KM-8030. The ad says just for TA-181/221 however these boards are as old as the hills and have been in use for over ten years as exactly the same board.
