Question about Frigidaire Dishwashers
Board caught fire - can I replace the board? Fridedaire model # FDB956RBC1
    Scholar:
  • 61 Answers
You could but i would not recomend it if it went on fire it was for a reason, it could be a faulty component that blew the board so you could replace it only to burn out another board which would be costly. if it went on fire its unsafe get a professional to check it out first, or claim your insurance?
Posted on Jul 22, 2009
Lighter caught fire electriic short nothing on dash works
No year make or model. But you'll just have to start taking the dash apart, and what all was burnt. Disconnect the battery because you don't want an airbag popping on you.
Dec 13, 2015 | Cars & Trucks
Boil element caught on fire and melted.
If element caught on fire, I would suspect stove needs cleaning. Do that then elements should not smoke for long. (I hope all moisture was removed from stove!!!)
Feb 11, 2014 | Kenmore Element Stove Burner Frigidaire,...
I have a goodman gas furnace with ac. the motor caught fire, replaced the motor,turned the system on, the outside condincing unit comes on, the relay will click but the fan will not run. i checked the...
First - you should be very careful when checking for 'power' with a ohm meter. I'm assuming you are pretty mechanical inclined (if you changed the motor yourself), but - just be sure to 'never' put an ohm meter (set on ohms) across power.
That being said - if you (indeed) have no power coming out of the circuit board - I would check and see if you have power 'into' the board - and generally speaking if you have power to the board but not out to your motor leads you are probably safe to assume the board is bad but not in all cases.
NOTE: Since your motor caught fire - I'm not sure I wouldn't have a "Service Tech" take a look at your problem and the entire unit just to make sure 'everything' is ok.
good luck!
May 07, 2010 | Heating & Cooling
Our Kenmore Dishwasher caught fire.
You may want to contact Sears to see if there was a recall on your model dishwasher. There were problems with the door assemblies on some model dishwashers that were caused by the rinse agent leaking into the wire harness of the door. Over time the rinse agent would corrode the wire insulation causing the units to catch fire in some cases. The fix was a free inner door and wiring harness upgrade kit from the manufacturer. Here is a link you can refer to that may offer some assistance:
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07190.html
Although I did not see your model number listed, you may want to call the Consumer Product Safety Commission number listed at the bottom of the page and report this incident.
I hope this offers some assistance to you.
Sep 17, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
Panasonic otr microwave model nn-s245bf, ventilating all the time, cannot use as microwave. thanks
I have the same problem. The control board (central processor) has caught fire. It's noticeable when you take the control panel off.
We need a new control board. I'm currently looking for how to get one. It appears to be a common problem.
Jun 16, 2009 | Panasonic NN-P794SF Microwave Oven
Same problem. GE Model #D52GW12 Working fine then just caught on fire. Removed the back and found a part that said "Focus and Screen" on it. Can this be replaced or do you have to replace the circuit...
the flyback... very common for the ge version of the rca it222 you may also have to replace the horizontal output transistor. i have found at the shop the flyback and the transistor ussally all that have to replace
Apr 29, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sears Kenmore Elite Oven 790.99123405 Caught Fire!!!
The PF indicates a power failure.
The range experienced a loss of electrical power.
This code is usually cleared by pressing the CLEAR/OFF button.
If you continue to get this code, you may need to unplug the range and check the wiring connections of the power cord on the back of the range.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 12, 2009 | Kenmore 99123 Electric Kitchen Range
Caught Fire
i need the model number
Oct 14, 2008 | GE JVM1870 Microwave Oven
Dishwashers Logo
62 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
