Question about Magellan Maestro 4250 Car GPS Receiver
Screen says: USB connected The USB has been
Screen says: USB connected The USB has been connected to the unit. Please follow instructions from PC application for updating maps or software.
Where do I get the instructions from the PC?
    President:
  • 1,111 Answers
If your trying to update your 4250, you can go here to get the latest update, which is 4.86
screen says:  USB connected The USB has been - 1ce5be8.gif
you will have to register the unit on the magellan site before you can download the update.
just make sure you follow the directions for the update exactly as it says!
if you need further help, id be glad to help you.
Posted on Jul 25, 2009
3 Suggested Answers
  • 59 Answers
SOURCE: When my gps is connected in my car this text shows
The car charger you are using for the unit is probably incorrect. If its not the OEM charger then it will put the GPS into "USB/PC mode".
Posted on Sep 24, 2011
SOURCE: My Magellan 3225 when plugged to the charger,
Bad USB port
Posted on Oct 19, 2009
Won't record
I suggest that you to select Reset to Factory Defaults in the System menu to soft reset reset the unit or by pressing Delete and the power button and holding them down to hard reset. Good luck!
Dec 14, 2007 | M-Audio MicroTrack 24/96
I havae panasonic KX MB 772, did i have to on its PC while installing its driver.... because when pc is on it demands for usb cable...when i connect the usb cable it doesn't detect....... plz send me...
Follow the on-screen instructions, do not use usb-extension cables. Try a new thick and short (well shielded) usb cable, connected it directly to the rear usb ports of your PC.
May 20, 2011 | Office Equipment & Supplies
Magellan Maestro GPS #MM3225. Screen display this
The unit is now connected to your computer, and you can actually access its filesystem through windows. It is also charging the battery in the unit. I wouldn't want to mess around with the files, though, unless you know absolutely what you are doing. Plus, it's also a good idea to turn the unit off before removing it from the computer.
Apr 18, 2010 | Magellan Maestro 3140 GPS Devices
Don't know how to transfer between unit and pc. Connected with the provided usb cable, unit displays the following: High Speed USB. That's it. Can't navigate anywhere else. Tried resetting, using a...
Before you hook up your player, check the settings in it. Find your settings menu and see if you can change it from MTP to MSC, look in your instruction book to see if that is an option. Then hook it up to your computer.
Dec 30, 2009 | Audio Players & Recorders
I just got a Magellan roadmate 1200 over the weekend from a friend and when I plug it in it loads to a screen that says the usb is connected follow pc instructions
The USB must be for charging the unit and downloading updates when it becomes available. You have to unplug the USB and use the battery power to put in addresses .My 1200 does the same.
Jan 05, 2009 | Magellan Roadmate 1200 Car GPS Receiver
ASUS EEE 1000H fails system recovery procedure
Shut down Comp. Hit F2 continually whilst powering up. Now go to boot up and make dvd boot first choice.
Save the settings and exit.
Unit will auto start restore.
Follow actions and don't try to rush things.
Dec 16, 2008 | ASUS Eee PC 1000H Laptop
I am installing a Canon Pixma IP4600. Have plugged in power and USB connection and get alternate green and orange flashes. Followed instructions to disconnect and reconnect the power and usb but to no...
What operating system you have?
If your printer is a USB printer then do the following: First of all please remove the USB Cable from your PC completely. Restart your PC without connecting USB cable back to your PC. Now connect the USB Cable into the USB Jack from both ends and start your PC. Your PC will automatically accept this USB Hardware driver. After doing above steps please reboot your PC finally and Let me know the result, so I can further invastigate the problem.
Scott
Dec 02, 2008 | Office Equipment & Supplies
Maestro 3250 Charging
I accidentally ran into this problem today when I inadvertantly plugged the wrong charger into the unit. I'm guessing that the device isn't getting the precise current it's expecting and thus thinks it's plugged into a computer. I'd suggest getting hold of a different charger and see if the problem goes away.
Jan 31, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4250 Car GPS Receiver Logo
1,188 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
