Question about Frigidaire Dishwashers
Dishwasher runs but water does not come into tub. Renters took the bottom rack from dishwasher. Could this be the problem?
    Novelist:
  • 108 Answers
The problem is your water inlet valve.
if you remove the panel at the bottom of the dishwasher you will see either a copper hard pipe, or a flexible steel hose leading into the water inlet valve.
BE SURE TO CUT OFF THE WATER SUPPLY. It is probably located under the kitchen sink- just follow the water line until you see a cutoff handle.
The valve is activated by an electromagnet- you will see a plug with two wires leading into the cylinder shaped solenoid (the magnet). After turning off the water, and disconnecting the water supply and the hose to the machine and the wires (it's a tight space, so be patient) check and see if the screen (just inside where the water supply line connects to the valve) is clogged with limescale. If it is, you can clean it out fairly well with CLR or Limeaway, and that might fix your problem. If it doesn't you can order a new one online, or take it to an appliance parts store if there is one in your area. They are pretty common.
Good Luck!
Posted on Jul 22, 2009
Dishwasher lights show "washing, drying, clean" like normal, but when it's finished I open it to find that the DW Detergent Pack never dissolved.
Make sure water is at least 120 degrees F.
As a test run water from the kitchen faucet closest to the dishwasher until it is a hot as it will get, put some in a cup then you can then check the temperature with a thermometer. OR you can just run the dishwasher to see if that helps.
Oct 20, 2015 | Whirlpool WDF750SAYM Gold Series...
I have a Frigidaire dishwasher, PLD4460. Only 4 years old. The dishes on the top rack are not coming clean anymore. Something as simple as left small bits of broccoli do not even get rinsed out of the...
Hi
If the top rack of the dishwasher doesn't get clean, check your appliance to see if you can fix the problem.
First check the spray Arms to make sure the holes in the spray arms are free and clear of debris. Your dishwasher should have several spray arms, including one at the bottom of the tub, one under the top rack, and possibly a third spray arm on the top of the tub. Sometimes food and mineral deposits can block holes in the spray arms, preventing water from spraying effectively. If this occurs, warm some white vinegar and pour it into a spray bottle. Spray the holes with the vinegar and dislodge debris with a toothpick or large safety pin.
Then check to see if your dishwasher has clogged filters. Filters generally cover the drain valve area to catch debris as the water drains from the dishwasher. Many dishwashers have maintenance-free filters, but your dishwasher may have filters that need cleaning. Read your owner's manual before you perform any filter maintenance to avoid damaging your dishwasher.
Check your water temperature to make sure it's hot enough. Water that is under 120 degrees Fahrenheit may not be hot enough to clean dishes effectively. Turn your kitchen hot water tap on and wait until the water warms up completely. Fill a cup and measure the water temperature with a kitchen thermometer. If the water is less than 120 degrees Fahrenheit, turn your water heater up to 120 degrees.
Load the top rack properly. Place cups and bowls upside down in the rack and don't nest dishes because this can prevent water from reaching dishes. Don't overload the top rack. Instead, position each item so the dirty areas of the dishes will receive full contact with water spraying up from the main spray arm located beneath the top rack. Prevent items from hanging below the top rack, which could prevent the spray arm from rotating.
Also check this link for more helpful info:-
http://www.ehow.com/info_7977311_top-dishwasher-not-getting-clean.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 15, 2011 | Dishwashers
I just got a new whirlpool dishwasher and it is leaking water from under the cabinet when operating. When I took off the small panel on the bottom of the DW I could see a drip coming from above somewhere...
Hello
Too much detergent can cause over-sudsing, which causes detergent suds and water to leak out of the door. Whirlpool recommends that you use between 0 and 6 grains per gallon for soft to medium water and between 7 and 12 grains per gallon for medium to hard water. Only use fresh detergent, as old detergent can also cause suds. Keep large pots and pans away from the dishwasher door. Water can bounce off of these items and exit through the seal. Always place dishes in the lower rack to prevent the spray arm from ejecting water right onto the door.
The door gaskets create a seal around your door, preventing water from escaping. If the gaskets are brittle or torn, you must replace them. Clean the gaskets if detergent or food particles are stuck to them. Level the cabinet if the dishwasher is unlevel, which can cause water to squeeze through the door. You can raise or lower the dishwasher feet. Tighten the door latch, if loose. Water temperature above 120 degrees Fahrenheit can also cause leaks. Test the water temperature by running the hot water faucet in your kitchen. Insert a waterproof thermometer into the water. Lower the temperature setting on your hot water heater if too warm.
Your Whirlpool dishwasher can also leak if the tub is filling up with too much water. Check the water inlet valve and the float switch. If either one of these components is stuck, the tub overfills. Replace the component. Examine the water inlet valve if water is dripping from this part. The valve has a tube that goes from it to the dishwasher. Replace the tube if split or punctured.
Your dishwasher has a main tub seal. This seal must stay wet, or it becomes brittle and cracks. Unplug the dishwasher, and remove the spray arm, lower rack and impellers. Replace the seal. You have both inlet and drainage hoses on the rear of your machine. These hoses leak if they are split or not connected properly. Replace any damaged or crushed hoses, and tighten the connections if loose. Verify that the washers inside the hoses are installed properly.
Aug 09, 2011 | Stainless Steel Whirlpool Gold 24 in...
Top (upper rack) of dishwasher does not wash. bottom does mediocre job
Make sure top rack is backed up into water entry in back of diswasher. Also check to make sure holes are not plugged in rotating wash arm. You may have to wash your dishwasher..take out the racks and look to see if they have food gunked up on them, if so wash them off in the sink. Take out the top rack clips and wash the rails inside the tub if they are dirty. You can use a squirt bottle with warm water. Do this after you run a rinse cycle so that dried food gunk is softer. There are alot of places in this machine for food to stick then resurface later. you may try also adding vinegar and baking soda to a rinse cycle and then leaving in it soak before restarting it.
Feb 10, 2011 | KitchenAid Dishwashers
I have a Kitchen aid tall tub dishwasher model #KUDCO3IVWH Yesterday the top rack didn't clean, today both racks stayed dirty - took apart the food chopper assemble and notice that there is water in the...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 26, 2010 | Kenmore 16372 / 16374 / 16379 Built-in...
Water standing in tub
If there is a lot of water sitting inside the applicance, it's possible that the high water float switch has been activated and is preventing the dishwasher from running. Open the door, remove the bottom rack, dip as much water out of the bottom as possible with a shallow ladle or even tupperware container. When that is accomplished, shut the door and try to run a drain cycle. If the unit won't start, you may have to remove more water. You don't have to have the rack in place to run the drain cycle.
Jul 09, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Water does not go in
First make sure that there is nothing on the bottom of the dishwasher tub where the float switch is located. Different machines locate them in different places on the bottom of the dishwasher tub below the bottom rack. If you pull the bottom rack out and find a plastic float and move it gently up and down you will probably hear a clicking sound. That is the switch inside the float. if that works and nothing is hindering it then go under the sink or where ever your water to the dishwasher is getting its supply and make sure the the valve is turned on and there are not leaking problems there. It these things do not work then I would start thinking on the pump being bad or the control panel for the cycles not working properly. Would need make and model number to help with that one... Hope this helps ya.
Oct 11, 2008 | Thermador DW44Z Built-in Dishwasher
Dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Jun 01, 2006 | Smeg 18 in. DWF410SS Slim-Line...
Dishwashers Logo
81 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
