Converting a panini grill into a crepe hob. Removed top element, now bottom element draws to much on lowest setting. What can I put inline or parallel to negate the loss of the second element?
Quite normal...top element is for grill/broil only. Bottom element is for bake only. If the grill element were to come on during baking a cake it'd burn the top of your cake to a crisp.
Some grill/broil elements cook at 500-700 degrees.
If you have replaced the grill element and it still doesn't work, there are a few other things you can check.
First, make sure that the grill is actually turned on and that the grill control knob is set to the correct temperature.
Next, check the grill's thermostat, which is typically located near the grill element. Use a multimeter to check the continuity of the thermostat, as a faulty thermostat can prevent the grill from heating up.
If the thermostat is functioning properly, you may need to check the grill's selector switch, which determines whether the grill or oven is used. A faulty switch can prevent the grill from working.
Finally, if none of these solutions work, there may be a wiring issue within the grill or in the main control board of the cooker. In this case, it may be best to seek the assistance of a professional technician to diagnose and repair the issue.
This is an unknown brand to us in North America and seems to be a South Africa brand?
The elements are individually controlled for baking with the bottom element and grilling with the top element. They only come on together if you have a 'rotisserie' setting.
If you are trying to grill and the element isn't working, then you need to make a warranty call.
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element. Here are the 3 main faults to look for in your oven or cooker that is not heating
1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set. The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control). To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
I've an EW 71 with exactly the same problem! Thought it was the element but then noticed that there were two elements to the top oven - so very unlikely that both would go at once.<br />Tested to see if the switch was the guilty party by turning it on using the upper oven switch and indeed both elements heated!<br />If yours is doing the same then it's the switch....<br />... So how does one replace the switch?<br />
<!-- from fixya rte -->
It would appear that you have faulty temperature regulators, which you will have to replace, for three to go together is unusual, have you spilt something on the top, because liquid could have got inside the control panel.
Please leave feedback.
Thanks.
