Question about Garden
My Push Mower series 080 works fine until it hits tall grass (over 6''), then it just cuts out and I have to restart it. it does this every time I go over tall grass. Is there a way to fix this Thanks, Sam
  • 44 Answers
If it has a grass box,mow without it and then mow again with box or use a strimmer and then mow.
Posted on Jul 22, 2009
Tucomse moer 5.5 Won't speed up when cutting tall grass.
These push-mowers have a limited power, when you hit tall grass there is much more resistance on the blades. Even higher power riding mowers can stall on tall grass.
Aug 04, 2015 | Garden
John deere la105
Grass is too thick & tall and may require a second pass until next time when it'll be easier to cut, or... blades are dull & need resharpening, or... tractor speed too high for the length of the grass.
Jul 31, 2014 | Briggs & Stratton Garden
How does the govener and carb linkage work on a Troy-Bilt 2005 800 Series (839) self propelled mower
Have you changed springs? Likely the correct components are there unless you have changed it. Does it run properly and at correct rpm when not in tall grass? Check for proper throttle adjustment first. also check for obstructions (packed grass for instance) under the deck that could be impeding the blade. Lastly, if you have the discharge blocked with a mulch plug, remove the plug. let the tall grass discharge. then run over it again and mulch it.
May 29, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Zero turn mower is sputtering and dies
Check everything is clean. Check the air filter is clean, check that the engine cooling fan, cutting blades and cutting deck are free of grass. Check all the drive belt pulleys to ensure accumulated grass is not jamming anything. Check the fuel filler cap is clean and the breather hole works.
Jun 27, 2013 | Husqvarna Zero Turn Mower Z5426
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
131 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
