Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
Dacor Oven Death
Hi All, The other day my Dacor ERD30 control panel lights went out and the oven doesn't work. Checked breaker and reset but no results. Top burners function fine.
I'm guessing fried circuit board? If so how much? (out of extended warranty by 4 mos of courseā€¦)
Any ideas would be greatly appreciated.
Thanks in advance.
    Problem Solver:
Re: Dacor Oven Death
i think first you should call dacor, 4 months is marginal - they should cover it
but if all else fail you can try this link ti diagnostics manual:
and this link to dismanling instructions:
good luck
Posted on Jan 10, 2009
0 characters
3 Points
Dacor ERD30 oven trouble
Check if both circuit breakers for the oven are on.
The control board needs only 120V but it should be 240V for the heating elements to function properly.
Check if there is 120V coming to the thermal fuse.
when you get your meter . put the oven on bake and check your power on the bake element if you do not have 240 volts then your control board is bad. if you have 240 volts then you element is bad.
Please don't forget to rate the solution.
Mar 25, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor rsd305
Once you replace the oven control again....never use self clean on any oven....unless you want to replace parts.
Before you replace the control...look inside the control panel for a resettable thermal fuse.
Mar 10, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
My Dacor wall oven will not turn on , control panel is saying u60 cooling fan.
If you can have an electricain check to make sure the wiring is all good that would be a start. It is NOT uncommon for a wire to come loose. If that is OK then you need a new fan. If the fan is not working or working properly then the unit will not work at all. With out the cooling fan the oven could overheat and start a fire.
Jan 02, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
ERD30S- oven wont turn on
Hi! jpdufilho
Try tuning off the power to the unit for 20 minutes. If this does not fix the problem you may need a new control board/panel. If you have a lot of lightning in your area you should have several surge protectors in your house. All electronic devices need some type of surge suppression.
Nov 09, 2008 | Dacor Epicure ERD30 Dual Fuel (Electric...
ERD30 will not reach or maintane setpoint
read your owners manuel and follow the instructions for adjusting the oven temp set it 15 degrees higher
Dec 31, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Oven not heating after self-cleaning cycle.
That did it for me too. You saved me a $200 service call!
Nov 05, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
530 people viewed this question
Top Dacor Kitchen Ranges Experts
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Jaime Hernandez
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
