Question about Kenmore 24032\24036 Top Load Washer
My agitator turns sopradically.
The agitator turns a little and stops. I can hold it down with my hand and it turns. But it feels like something is stripped. What can I do about it?
    Genius:
  • 1,122 Answers
Pop the cap off it,you will see 4 little gears called dogs,theses have to be replaced they work the agitator-mike
Posted on Jul 22, 2009
I want to remove the Agitator. User Manual says 10mm bolt inside Agitator. But it doesn't Undo or Tighten- DOESN'T feel like its stripped -Could Drive shaft just be turning with bolt? Ron
You will have to hold the shaft underneath while you turn it, most likely it came a bit loose, but is rusted holding to he shaft, but no longer to the agitator.
Mar 17, 2015 | Washing Machines
I caught a piece of plastic bag in the power mate. The overload/ reset button is now lit and the agitator won't turn. I have taken the head apart removed the agitator and put it back in place, and there...
Try turning the agitator by hand-double check all is free and you have not missed anything-check manual for reset button-some buttons you have to hold down to reset-the manual should tell you how to reset
Jan 06, 2014 | Kenmore 28015 Bagged Canister Vacuum
What's the cause of my washer's agitation and noise problem?
Possibly a bad basket drive. Or something is wrapped around the shaft under the tub or something is in the pump.
Aug 30, 2012 | Washing Machines
I have a Whirlpool LSN1000LW0 Washer. How do I separate the agitator to replace the dogs?
remove the fabric softner assemble.if ther is a plastic cover remove it remove 1/2 bolt and reach down under agitator up. put agitator on the floor.put a foot on both side's of the bottom of the agitator.place a hand on both side's of top part of agitator and pull up.turn top agitator upside down and the dog's should come out along with the holder.replace the dog's.to put holder and dog's back in top agitatoruse your 1/2 socket and exstention.place the 1/2 bolt in socket and place holder and dog's on bolt.turn top agitator upside down and feed holder and dog's up in top agitator.holding socket and exstention in top agitator,rotate top agitator down holding dog's and holder in with socket and exstention.place top agitator over bottom agitator and line up the two aliment ear's on bottom agitator and use exstention to push top agitator down on bottom agitator.place agitator back on transmition shaft and replace 1/2 bolt.replace plastic cover and fabric softner assembly.
Nov 15, 2009 | Washing Machines
In spin cycle agitator makes a noise like a hand saw in wood. At full speed the agitator will make a loud pop and stop for a moment,if I hold the agitator it does not pop.
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 14, 2009 | Kenmore Washing Machines
Can't remove lower agitator - Kenmore 110 top loader
Mar 15, 2009 | Kenmore Washing Machines
Loose Agitator
Usually, there is a bolt that holds the agitator on. If you remove the cap off the center of the agitator, you should find a bolt underneath that you can tighten back down. Adding a little thread lock to the bolt wont hurt.
Jul 10, 2008 | Maytag PAV2300 Top Load Washer
Adjetator (sp) isn't spinning properly .
The agitator dogs (little dog ear gears) are stripped. This is a very easy fix and the new dogs are very cheap. Go down to an appliance part store and ask them for agitator dogs for a direct drive whirlpool washer. Ill help too with installtion
Jan 12, 2008 | Washing Machines
Washer will not agitate but will spin
You are correct that motor turns one direction for agitate and the other for spin. The problem you describe sounds serious but there is a chance it is not. First, try to turn the transmission by hand. If it wont turn by hand, remove the agitator and see if something has gotten under it and has it locked to the basket. To remove the agitator, pop off the top cap and look down inside. You will see the bolt that holds the agitator on. After you take it loose the agitator will slide off.
If there is nothing there, the transmission will need to be replaced. If the washer is less than 5 years old, the transmission may still be covered by warranty. Check your owners manual for warranty details. Post back to let me know what you find out.
Oct 21, 2007 | Maytag Atlantis MAV6260AWW Top Load Washer
AGITATOR
There is a is a cheap part that fits at the top to make it agitate. Go to your friendly dealer, buy and install. These go frequently.
Apr 28, 2007 | Whirlpool LSW9700P Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
62 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
