Question about Whirlpool LHW0050PQ Front Load Washer
Door wont open
Door handle shows no resistance when pulled machine works fine locked door light is flashing as if it should open.
It opened 40 minutes earlier before i put dryer on?
Managed to pull back casing on door to reveal the handle and pin holding it together. Once i had pulled pin up slightly the door opened to reveal the door handle catch had broken. Engineer has fitted a new handle and everything is fine.
Posted on Jul 23, 2009
2003 VW GOLF REAR door wont open
The rear door lock actuator has failed in the door locking unit this is a common problem you can manually unlock the door to replace the latch if you didn't have the deadlocking on if you cant try pressing the locking button twice so when the car is locked the flashing red light is not blinking ie off on the drivers. Doing this usually causes the faulty lock to release the dead locking so you can pull the inside handle to unlock the door.
Oct 13, 2016 | 2003 Volkswagen Golf
I have a 1999 kia sportage my driver door is closed an it isn't locked but it will not open for the outside handle or the inside handle what do i do to get it to open can't take panel off
If it's not locked but the handles aren't responding (they feel like they aren't really pulling on anything, no resistance) and the interior lights don't turn on when you pull the handles, you may have no choice but to get into that door panel. It's possible the door opening mechanism attached to the handles has broken, and should be looked at.
Aug 04, 2015 | Kia Cars & Trucks
98 accord door handle broke door will not open
A non electric door, (which?) wont open,lock works ok, handle wont open the door.
What can I do to fix it.
well telling the door to us would help, and options.
so no electric locks,
there are 2 levers. one inside and one outside.
so you pull the door card (inside door covering)
and look at both locks , the inside pull, its it working?
then look at the key lock cylinder. is it connected still
and last are both connected to the latch mechanism.
one can cycle this latch lever inside the door shell.
if that fails the latch is busted.
all this is covered in the FSM ,why not read it.? (under body)
free , too.
http://hondatech.info/downloads/Auto/Manuals/Accord/
Nov 25, 2013 | Honda Accord Cars & Trucks
2003 X tpye Jaguar driver's door will not open from outside -- handle appears to be disconnected- the remote opener stopped working several weeks ago -- key will lock all doors but driver's do
I had the same problem in my 2002 not isn't back I got a tin of wd 40 put the straw applecateter in the key hole and give it a good dose after 10 minute it open did it again now it works fine so I did them soon to make shore try it before you have to pull the door panel apart
Jan 12, 2013 | 2003 Jaguar X-Type
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
I have a 1998 jeep cherokee and can not open rear (trunk) door It feels like the key is unlocking and locking, but raising the door handle will not let me open the door?????
spray a light lubricating oil into the locking or catch mechanism, you will need to have the door opened already though. WD 40 should work well. I have a 98 cherokee limited and had a similar problem when I purchased it used. It would lock and unlock, but it wouldn't open. To first open it I had to push the handle down while I pulled the latch up.
Aug 21, 2009 | 1998 Jeep Cherokee
Machine stops, "door open light" flashes door is securely shut.
bad door lock and or harness replace door lock assy and check all connections
Jul 07, 2009 | Washing Machines
Door lock light
First thing to try is some WD 40 on the lock mechanism on the machine. Plug off the wall first. A catch on the mechanism may not be working to indicate that the door is locked to the control panel.
Caution after wash wait for a click in lock area or wait for 3 minutes to open the door; do not force the door.
Jun 10, 2008 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool LHW0050PQ Front Load Washer Logo
303 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
