Ovens Logo
S
Shelly Tweedy Posted on Jan 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Viking DESO530 oven, the display is blank (usually shows clock) when you hit Oven on it flashes but the oven will still work if you hit the button - is that a control board or relay board problem?
Confirmed with electrician its getting full power to the oven
Ken Wieczorek
Level 2:
Sergeant:
  • Viking Expert 451 Answers
  • Posted on Feb 02, 2017
Ken Wieczorek
Viking Expert
Level 2:
Sergeant:
Answers
451
Questions
0
Helped
227983
Points
825
I would guess interface board .board with LED on it
How Does An Electric Range Oven Work Appliance Repair
How do I get viking oven veso1305 off military time
To change the time display on your Viking oven from military time to standard time, follow these steps:
  1. Press and hold the "Clock" button on the control panel until the time display starts flashing.
  2. Press the "Plus" or "Minus" buttons to adjust the time to the correct standard time.
  3. Press the "Clock" button again to save the changes and exit the time-setting mode.
Regarding the codes that appear when you press and hold the "Clock" button, these are called diagnostic codes and are used to troubleshoot problems with the oven. The codes will vary depending on the specific model of your oven and the specific issue being diagnosed. You can usually find a list of the diagnostic codes in the owner's manual for your oven, or you can contact Viking for more information.
Jan 03, 2023 • Ovens
2answers
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
2answers
Built-in oven-- clock unresponsive
You do not need the clock I removed it and wired the oven direct.The wires are easy to get at when the front panel is removed. If you look at the manuals on line they will guide you with the correct wires to use
1helpful
2answers
Oven clock no display and oven wont work any way to bypass clock new world cgk 21556
These things are a pain! When you first power up a lot of New Workd ovens, they come up in AUTO mode and the oven won't work, so you have to take it out of auto mode and stop the clock flashing. I'm giessing that though your clock DISPLAY isn't working, the clock is and the oven think it is.
There are 6 buttons below the clock display.To take it out of AUTO and stop the clock and oven thinking the display is flashing:
Numbering the buttons from left to right as 1,2,3,4,5 and 6 (because they have silly symbols!) press the 4th button (a picture of a hand) you will hear a little click and the oven will now work. If you have to power the unit off for more than about a minute at any time, you will need to do this again
13helpful
My Blanco oven will not work. Display shows 0:00 'auto' flashing. Cooktop works fine. I have checked the manual but it was of no help. Model number is BF95W. Tried turning off/on at power. This did...
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
May 29, 2011 • Ovens
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
The oven works but the display remains blank when oven is not in use. If we press on the clock button, the time shows but then goes black again.
You just need a new oven control! It is simple to replace. Just give us a call with your brand and model number and we'll get the correct part out to you first thing in the morning! We look forward to working with you!
Oct 18, 2009 • Ovens
My viking electronic oven display blank
Contact Viking. I am pretty sure that the display unit still has a parts warranty.
54helpful
9answers
KitchenAid Superba Double Oven clock won't light up
hold down the clock button for 3-5 secs. youve somehow toggled the clock dosplay off.
Nov 05, 2008 • Ovens
Top Viking Ovens Experts
ZJ Limited
ZJ Limited
vince
john h
Are you a Viking Oven Expert? Answer questions, earn points and help others
