Question about E-Machines eMachines Desktop PC
Computer won't come on
I have a similar problem with my emachine. It is connected to a monitor and it comes on and makes sounds and lights up but, still I get no picture. I know that the hard drive is fine and I have tried a new monitor, added a new video card and still nothing. I would love to get a helping hand with this cause I would love to keep this PC.
  • 205 Answers
Does this computer have on board video? You mention that you added a new video card. Did you remove an old video card?
Do you see anything at all on the monitor at anytime while booting?
If it has onboard video have you checked the BIOS to insure that it is enabled?
Posted on Nov 20, 2007
I have a 5 year old Emachines computer, a few weeks ago I bumped my foot on the desk that was holding the computer and the screen turned off and the tower started beeping. It was long continuous beeps. I...
Usually when you hear long beeps coming from your computer it telling you that there is hardware loose . You may have knocked something loose. Check cd roms , ports and cards , memory to make sure they are fitted in correctly . good luck
Aug 03, 2017 | Computers & Internet
My ET1161 computer won't recognize my monitor how can i find out whats wrong?
1) Please make sure the monitor is on and securely plugged in both the monitor and the back of the computer.
2) make sure that you are using the right input in the back of your computer for your monitor as some computers have an internal video card and external. Please test the monitor on both connections.
3)If possible please test the monitor with a different computer to make sure the monitor itself is functioning.
May 06, 2011 | eMachines ET1161-05 PC Desktop
Emachine not starting up.
the screen is blank? when it is like this and you pree number lock or caps lock, will it turn those lights on and off on the keyboard? If so, I would just check the monitor connection, those connections can get loose, get dust in them, or ever have the connectors wear out after a long life.
Mar 02, 2010 | eMachines T3604 PC Desktop
When I turn on computer, the blue light comes on and the computer makes sounds as if it is starting and the monitor light is yellow. If I turn the monitor off and then back on, the screen says something...
No input usually indicates the machine is having trouble getting a video signal from the monitor. Check and make sure the monitor cable is connected properly. If you have another monitor also test the machine with another monitor.
Feb 26, 2010 | E-Machines eMachines Desktop PC
How to connect emachine flat monitor to my computer?
It sounds as if you are missing the power cord for the monitor. If the cord did not come with your monitor/PC, you can pick one up at any Radio Shack or electronics store. If you could forward me your eMachine model number as well as the monitor model number, I will see if I can better solve this for you without you having to spend anymore money.
Best Regards,
Franklin, C2Solutions
Jul 21, 2009 | E-Machines eMachines Desktop PC
Emachine light, fan and harddrive come on only.
Please check the cable between monitor and computer and make sure everything is properly connected. try unpluging and reconnect it.
Thanks,
CF
Jun 25, 2009 | E-Machines eMachines Desktop PC
Monitor on emachines computer is black and the on/off light flickers screen will not come on
First make sure the power cord is plugged in both ends (in the wall and in the monitor).
When the computer is turned on, it should run a power on-self test and then beep. The monitor light should be green and then the Windows splash screen will display. If your computer starts up but the video fails, then the monitor light will turn yellow.
A monitor light that just flickers and goes off is probably an indication that the monitor has failed.
I usually try to hook up another monitor (borrow it from a friend) just to be sure that the computer is working.
Jan 22, 2009 | E-Machines eMachines Monitor E15T4
Emachines model 780 monitor comes on for one second then goes blank
CANNOT COMPUTE!!!! NEED MORE DATA! Is your monitor the problem or the computer? Try connecting the monitor to another computer. You can also try connecting a laptop with an external video adaptor to the monitor to test it.
Oct 12, 2008 | E-Machines eMachines Desktop PC
Monitor won't come on
Lets start with the basics. Does the monitor have power, do you get a light on the monitor when you try to turn it on? If you do then do you get any lights on the computer when you try to turn it on? If the monitor has no lights on it check the power connections and if still no lights then try plugging it into a different outlet preferably directly into the wall. If still nothing then the monitor is bad. If the computer has no lights but the monitor does once again try plugging it in to a different outlet and if that does not work there is a problem with the computer most likely the power supply, CPU, or motherboard. If both have lights but you get no display on the monitor then check the connection between the monitor and the computer. if the connection is good (I would ***** in the screws on the sides of the connectors just to make sure there is a good connection) then there could be a problem with your video card.
Mar 12, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
82 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
