Question about E-Machines eMachines Desktop PC
My emachine will not boot up
It says on the screen that ''windows> could not start because the following files are missing or corrupt
    President:
  • 3,278 Answers
In the removal process, you may have removed the hal.dll file. The system configuration has changed and Windows is looking in the wrong place for it.
If Windows XP, use the XP installation CD. Change the boot order and boot from the CD.
First, try to restore the hal.dll file from the Windows XP CD. Boot your system without the CD.
If that doesn't work, use the Recovery Console which should fix the problem.
If not, more extensive work, such as Windows Repair or Clean Install would be necessary.
Hope that helps.
Posted on Jul 22, 2009
    Problem Solver:
  • 5 Answers
You may use any XP cd weather or not its yours to correct and reinstall corrupt and missing files.
Posted on Jul 26, 2009
  • 3 Answers
I am still new at this, but i had a simular prob. check any backup files , if you have them, to copy the file agian or if you do virus scans and save the logs, check them. they have been helpfull to me.
Posted on Jul 25, 2009
  • 284 Answers
You might try restoring the last known good configuration.
Press F8 over and over before the windows logo comes up.
You should get a text menu showing lots of options like safe mode etc. One of them should be last known good configuration. It may replace your corupted file with a known good one.
HAL.dll is the Hardware Abstraction Layer or something like that. It kind of acts like a go between for your Hardware and Operating system. So if this file is stuffed you don't have much chance of it booting. You might find some advice on Microsoft's web site relating to a corrupt hal.dll. I found some directions here on how to replace that file from the os cd. http://pcsupport.about.com/od/fixtheproblem/ht/restorehaldll.htm
There is a lot of advertising but just read carefully it seems like good advice.
I cannot boot up my Microsoft Windows 7 due to a corrupt ntfs.sys file. I can access command prompt through computer or cd. Please help!
As you are able to access command prompt, you can run the "System File Checker" tool to repair/ replace the corrupted ntfs.sys file. To do this, follow the instructions below:
1.Restart your system and tap F8 key repeatedly until you see Advanced Boot Options menu on your screen. If you miss reaching the screen in the first attempt, repeat this step until you reach the screen.
2.On the Advanced Boot Options screen, select "Safe Mode with command prompt"
3.In the command prompt window, type "SFC /scannow" (without quotes).
Note: There is a space between C and / in the command above.
This will scan all your protected system files and replace the corrupted files with a cached copy stored in your system.
Important: Please do not close the command prompt window until the verification is 100% complete. After the process is completed, the scan results will be displayed on your screen.
To know more about System File Checker, you can refer to the following Microsoft support page:
http://support.microsoft.com/kb/929833
Hope this will help you.
GuruAid.com
Aug 17, 2014 | Computers & Internet
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Dell Latitude 810 will not boot. When computer is turned on a black screen appears with the message "Windows could not start because the following file is missing or corrupt: <Windows...
Boot to the WIndows XP CD (Press spacebar when prompted to press any key) at first prompt in setup, press R to enter recover console.
At the C:\Windows\System32\> prompt type bootcfg /rebuild then press enter
http://support.microsoft.com/kb/330184
reboot see if error resolved.
If not then try running diagnostics by pressing Fn plus power button, see if there is a HDD malfunction
Jul 16, 2011 | Dell Latitude D810 PC Notebook
On screen message telling me windows could not start because the following file is missing or corrupt- &lt;windows root&gt;\system32\hal.dll. Laptop does not start or boot properly
Time to get out that restore disc you made when you first got your laptop. The boot sector has errors. Boot with your rescue disc and run CHKDSK/F to clear the errors.
Hope that helps.
Feb 16, 2011 | ASUS Eee PC 701SD 8G Notebook
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
My computer is not able to boot, it gives msg as follows File: \ windows\system32\config\system Status: 0xc000014c Info: windows failed to load because the system registry file is missing, or corrupt it...
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully. 8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Nov 27, 2010 | Microsoft Windows Vista Ultimate Edition
Won't finish boot because bad or missing system32/drivers/ntfs.sys file
There's a few ways to fix this. Easiest way is to just reinstall your operating system. That will wipe out everything and i assume you have data that you don't want lost.
Here is an alternate route. That file is stored on the disk in the I386 folder. Below is a link with the directions.
http://support.microsoft.com/kb/822800
Be prepared, there is still a chance you could lose your data, but the above link gives you the best chance at fixing the problem.
Oct 26, 2009 | Microsoft Computers & Internet
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Sep 05, 2009 | Microsoft Windows XP Home Edition
Turn on emachine, and dos menu pops up saying windows could not start because the following flile is missing or corrupt: WINDOWSSYSTEM32CONFIGSYSTEM then under that it says, you can attempt to repair this...
Borrow an installation Cd of your OS. Configur your computer to boot from CD.
Boot from CD, Choose (R) repair option. The recovery Console appears. Enter the number (1, 2 or other) that corresponds to the partition the system detected. If you see only one installation then you enter 1. You will then be asked to log in as administrator by supplying the password you entered whwn you installed.
When the C:\> prompt appears type
COPY [your_file_name] [SPACE BAR] C:\WINDOWS\system32\ [your_file_name]
After that Press [CTRL][ALT][DEL] to restart.
It should copy the missing file and you will be able to reboot.
Hope it helps
Rate the solution if it solves your problem.
Sep 01, 2009 | E-Machines eMachines Desktop PC
Aspire 5610 file is missing or corrupt
The error message means you use the Windows installation CD to repair Windows by booting up with the Windows CD and select r at the first screen to start repair.
Apr 08, 2009 | Acer Aspire 5610-2328 Notebook
E-Machines eMachines Desktop PC Logo
505 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
