Question about Aiwa CDC-MP3 CD Player
Ejects CD every time it is turned on
My brother and I recently transferred my CD player to a different car, and hard wired it without using a harness (which we have done a few times before). However, everytime I start up my car, the CD is ejected and the CD player is off. It then turns on when I push the CD back in, and starts at the beginning.
I realize this is probably some simple wiring mistake, as it seems to not remember where it was each time the power to it is cut. Also, sometimes if I only turn off the car for a minute or so, it wont eject the CD but will still start at the beginning.
Any help with what mistake we could have made when wiring and how to fix it would be very much appreciated. Thanks in advance.
Yup switch your yellow wire to the one u have the red wire attatched to and vise versa red wire to the one u had the yellow attatched to from the cd player. u just got the two power wires backwards is all
Posted on Aug 15, 2010
  • 78 Answers
It sounds like you have got the permanent live and the switched ignition live the wrong way round. if you check which positive 12v supply goes off when you turn the ignition off and remove the key and connect that one to the one which stays 12v when the key is turned off and vice versa that should solve your problem
Posted on Nov 21, 2007
4 Suggested Answers
  • 86 Answers
SOURCE: CDs wont play
archo69..big chance your laser is on its way also can be the bottom lense is dirty to ,but this requires your stereo to be removed .dismantled and cleaned manually
Posted on Feb 08, 2008
  • 2226 Answers
SOURCE: cd will not eject
you can try disconnecting power to the stereo for a few minutes. sometimes the reset switch doesn't always completely clear the memory of the uprocessor.
Posted on Mar 09, 2010
  • 5 Answers
SOURCE: Cd is not ejecting from aiwa cdc-x207 I put it in
there is a small hole in the front panel, straighten out a paperclip and push one end into this hole until the tray releases.
Posted on Apr 13, 2010
How to wire cd player up in 2000 chevrolet malibu
I just discovered there are wiring harness adapters as I used one on my car to install a new cd player recently. I found this one on the internet not sure if it is the same car you have.
then you can buy a harness adapter from this adapter to the make of cd player like as an example Kenwood Cd player adapter.
A car auto store may know about these wiring harness adapters the advantage of using them is it makes it easy to install the cd player and if you ever decide to change the cd player in the future you can buy the adapter suited to the future player and plug it into the malibu car wiring adapter as the car adapter converts the factory wiring into a universal wiring standard.
A tip
make sure the radio and cd player works and the climate control work properly before completely re assembling the dash board .
I forgot the aerial cable plug !
I used Aeropro brand of wiring harness for my car that I got from
Car Accessory store in my country . I had to cut one wire and connect it to Pontrol to get my power aerial to work correctly. Which the store salesman helped me work out which wire controlled the cars power aerial
Sep 17, 2015 | Chevrolet Cars & Trucks
How hard would it be to put a different cd player in my 2003 Monte Carlo SS ??
It is very simple actually. What you will need is a face plate, an aftermarket wire harness and the skills to connect this wire harness to the new CD player harness, they are usually color coded so very simple. TO remove you stock CD player you will need to pry off the plastic surround then there are 4, 7mm bolts that will need to be taken out and the stock CD player will pull out. Unclip the wire harness and antenna
Apr 01, 2010 | 2003 Chevrolet Monte Carlo
I would like 2 connect mazda wire harness to nextar ncd50.HOW CAN I CONNECT that can u plz explain me
It depends on if you have an after market wiring harness that adapts the factory harness to the new cd player, or trying to hard wire into the factory wires in the car. First off, if you don't have a aftermarket harness, i would strongly suggest picking one up from Wal-Mart or automotive store, they are around $20 and save a lot of time. If hooking up this way, you just have to match the color wires to the same color of wires on the cd player. Red to Red, which is power, Yellow to Yellow which is Constant power, Black to Black which is Ground, Blue is only used when you have a power antenna that goes up when the car is turned on or if you have a amplifier, you can hook up the remote power to it, otherwise, leave it off. Then you will have your speaker wires which the fronts are White and White/Black, and Grey and Grey/Black. The rears are Green and Green/Black and Purple and Purple/Black. The ones with the Black striped go with the other matching colors with the black stripe. Then you would just plug in the factory harness to the aftermarket, and aftermarket to the cd player. If you are trying to hard wire into the factory wires, you will have to cut of the harness, find a Haynes or Chilton book at an automotive store and find what wires are what and use the color codes from above to hook back up, factory wires are always different colors. Once again, I strongly advise not to do it this way though. Hope this helps. Good luck.
Mar 12, 2010 | Car Audio & Video
My radio harness was cut and tring to install cd
okay you will need to hard wire it in the vehicle. so i will need to know what year make and model car you have?
Jan 31, 2010 | Clarion DXZ645MP CD Player
CD keeps ejecting without playing.
try reformatting the cd or try a cleaning cd, the more you pay the better the cleaning cd
Nov 06, 2009 | Pioneer FH-P4400 CD / Cassette Player
Your best bet on that one is to go to a place that sells car audio systems or even some autoparts retailers have them,and get the proper adapter harness already made up. A few more dollars but, a whole lot less headaches.
Mar 06, 2009 | 2002 Dodge Caravan
Tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Mar 04, 2009 | Pioneer DEH-P6400 CD Player
ILO XM-MP3-CD Car Stereo wiring
they all use the same colors. Every CD/DVD player manufacturer uses the same color scheme on all the same wires.
If you're asking what the right wires are in your car i'd get a wiring harness and just match up the wires and plug it in.
However if you're just going to cut off the car wiring harness and splice everything in go to and use the guides they have.
Jan 31, 2008 | iLO XM-MP3-CD Car Stereo
Aiwa CDC-MP3 CD Player Logo
158 people viewed this question
Top Aiwa Car Audio & Video Experts
Greg Cann
Greg Cann
Are you an Aiwa Car Audio and Video Expert? Answer questions, earn points and help others
