Question about Tomtom One XL GPS Receiver
Why there are three wires in battery of Ton Tom one
My TT One have the usb internal connection broken
I want power the tt using on DC 3.7 volt on ion battery directly
but the battery have THREE wires and i dont know all voltages on all wires (black, red yellow)
  • riky_none Jul 22, 2009
    the battery is low and i know only the voltage of battery 3.7 Volt
  • 284 Answers
You can get a multi meter from an electronic story really cheap.
It will tell you the voltage and the polarity of the battery connectors.
Posted on Jul 22, 2009
I have a 2001 triumph TT 600 that is idling rough and is backfiring any idea on what it could be?
Hi, Joe and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a "LOAD" test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.triumphrat.net/maintenance-and-workshop-talk/101962-tt600-year-2000-cut-out.html
http://zkmc.org/pdf/1014488-Triumph-TT-600-03.pdf
Hermys Triumph Motorcycle Parts Triumph TT600 Genuine Motorcycle Parts in...
http://mybikemanuals.com/triumph
Triumph TT 600 2001
Mar 18, 2017 | 2001 Triumph TT 600
Ttr 125 will kick over but not stay started
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
TTR125 Starting Idling issues TTR
TTR125 hard start problem FIXED
YAMAHA TT R125 Owner Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-tt-owners-manuals
Apr 17, 2014 | 2002 Yamaha TT-R 125
Engine miss firing and backfiring
backfire and missfire
Diagnosing misfire or backfire
YAMAHA TT600R Service Manual
Apr 16, 2014 | 2000 Yamaha TT 600 R
TT-R 125 L not charging
Hi, Anonymous the systems check below is geared towards Harley Davidson so exact numbers might differ slightly with book specs on your bike but the basic principal is the same, in order to check out any main electrical system, you have to start with a fully charged battery 12.5 volts or better, and be able to pass a load test if necessary. "WARNING" never plug or unplug any electrical connector with the engine running !!!
1. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
2. Check the voltage drop at the battery when you hit the starter button, anything below 9 volts you might have a faulty battery.
3. Check voltage at the battery with the bike running at 3,600 RPM should be 14.3 to 14.7 volts. If you are not getting these numbers, you might have a faulty voltage regulator.
4. Make sure voltage regulator is "GROUNDED" and functioning properly, watch the video below on how to test a voltage regulator.
5. Unplug the connector to the alternator and hook your multimeter leads to the alternator (pin/socket selection does not matter) set the multimeter to AC volts, at an idle the multimeter should read 16 to 20 volts AC. at 2,000 RPM 32 to 40 AC volts, 3,000 RPM 48 to 60 AC volts. If you are not getting these numbers, you may have a faulty alternator rotor.
6. Set the multimeter to OHM'S, connect one lead to the alternator (any pin/socket) and the other to a ground, the multimeter should read infinity. Connect both leads to the alternator multimeter should read 0.1 to 0.2 OHM'S. If you are not getting these numbers, you have a bad stator.
7. Check all wiring in the charging circuit for worn or chaffed spots and all wiring connectors in the circuit for corroded, broken, or loose pins/sockets, which is the # 1 offender.
Dirt Rider Magazine
TTR125LE electric starter not working
YAMAHA TT R110E Owner Manual
Mar 07, 2014 | 2005 Yamaha TT-R 125 L
Tom sat nav
You will probably find that your internal BATTERY is now well past "its useful lifetime" [around 2 -3 years plus]. The same thing [and symptoms] happened with my 10 year old TOMTOM OneXL.
I was quoted $80.00 [by TT here in Australia] to possibly fix it + the cost of the battery ???
SO I purchased a new TT Via 280 with LIFE-TIME FREE MAPS for just over AU $240.00 ... Works GREAT and better maps as well !!!
Nov 18, 2013 | GPS
ALL Voltages (three wires) iones battery of Ton Tom one
Not sure why you would need to know this , red is live black is return circuit and the yellow is auxilliary and usually goes to charge input. as a live wire It is easier to cut and graft a new battery to the stubbs of wire than to solder new battery on. What you might really be needing is the polarity.. whether any charge pin is positive or negative if you are making a new internal charge point. Consult the back of the charger it usually states the polarity in a graphic.
Jul 23, 2009 | Tomtom One XL GPS Receiver
The Logo screen freezes on start up.
Connect it to your pc then turn it on. It should either connect or ask you to connect to the pc. If tt home opens shut it down. Do a complete backup of your unit onto the desktop. DO NOT USE TOMTOM HOME TO DO THIS!!!! After doing a complete backup format the drive on your tt useing fat 32. Open tt home and let it reload your os. Do this a couple of times to get the newest os. Disconnect your tt from the computer the way you normally do and restart your tt. Reconnect your tt and do not let home start. Go to your backup and copy and paste your maps back onto the root of your tt. If you have any question email me.
Hope this helps
May 07, 2009 | Tomtom GO 920 GPS Receiver
Bought new tomtom one. need to info off old tom tom.
When you conect ypur old TT to pc you need tt home software (http://www.tomtom.com/support/support.php?ID=3&Language=1) just use export favorites files (copy to copmuter) then connect the new tt and use import option (copy to tt)
Feb 13, 2009 | Tomtom ONE GPS Receiver
Format 4gb sandisk sdhc card to be compatible with tom tom go 510
  1. Format the card in your PC's card reader as Fat32
  2. Insert the card in your TT, turn on your TT, connect your TT to your PC, and from your PC find the drive letter that corresponds to your SDHC card
  3. Now format the card in your TomTom using Windows - don't worry if it formats to a lower capacity.
  4. Turn off your TT, remove the card, place in your card reader
  5. Format your card using "Quick Format"
Sep 07, 2008 | GPS
Xerox Phaser 7700 displays error 7-276
Here is the documentation on that error
07-276 TRAY 3 PAPER SIZE SENSOR BROKEN (TTM)
EXPLANATION
An abnormal AD value was detected from the Tray 3 Paper Size Sensor.
Refer to BSD: CH7.4 CH7.13A
Procedure
Set Tray 3 in the machine.
Between Tray Module PWB J548-11 (3T: J548-11 , TT: J548-11) (+) GND (-)
Is the voltage the same as that in the Tray 3 Paper Size Sensor Output Table inscribed in BSD: CH7.4?
Yes No
Between Tray 3 Paper Size Sensor J820-2 (3T: J820-2 TT: J820-2 ) (+) GND (-)
Is the voltage the same as that in the Tray 3 Size Sensor Output Table inscribed in BSD: CH7.4?
Yes No
Between Tray 3 Paper Size Sensor J820-1 (3T: J820-1 TT: J820-1 ) (+)J820-3 (3T: J820-3 TT: J820-3) (-)
Is the voltage +5VDC?
Yes No
Using the wire network from Chapter 7, check the +5VDC circuits to Tray 3 Paper Size Sensor J820-1
(3T: J820-1 TT: J820-1 ).
(WN 7.3.6 +5VDC-2)
Check for malfunctioning paper guide, poor contact caused by bending in the projection that pushes the switch, and
if there is no problem, change the Tray 3 Paper Size Sensor. (PL16.1)
Check for cut wires, poor connections between Tray 3 Paper Size Sensor J820-2 (3T: J820-2 TT: J820-2 ) and Tray Module
PWB J548-11 (3T: J548-11, TT: J548-11)
Change the following parts successively:
TRAY MODULE PWB (PL16.9)
MCU PWB (PL13.1)
ESS PWB (PL13.1 ).
Apr 26, 2008 | Office Equipment & Supplies
Tomtom One XL GPS Receiver Logo
232 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
