Question about Ovens
No heat from my oven everything else is working
    Novelist:
  • 108 Answers
If it's gas, there is about a 99% chance it is the igniter, (to see the igniter you will have to remove the bottom panel from the oven- at the back of the oven you will see a small stick shaped piece with two wires connected to it. Oftenn, but not always, bad igniters are visibly cracked, or sometimes even shattered) and if it is electric, there is about a 99% chance it is the element (you will probably be able to see a whitish discolored crack in the element). Both are fairly easy to change.
You will have to look online for replacement parts most likely, just be sure to get the model number from the sticker on the oven (usually on the inside of the bottom drawer if there is one) when you look up the part.
Also, when changing parts, UNPLUG the unit.
Posted on Jul 22, 2009
Have a chef fan forced wall oven model number EOC624W - everything working except there is no heat
Check the house circuit breaker for the oven. If 240 isn't present, everything else will work except the heating element. The circuit breaker will have it's handles joined so if one trips they both trip. Unfortunately, this doesn't always work, Meaning one can trip without tripping the other so only 120 volts is supplied to the oven.
Dec 13, 2016 | Ovens
The oven does not heat up. the microwave work and everything in terms of the display on the oven works, but no heat.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ][
May 08, 2011 | GE JTP86 Electric Double Oven
Oven was on, heard a loud bang and everything went off, changed fuse, oven clock etc came on, grill works but oven does not work?
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Jan 19, 2011 | Ovens
Maytag Gasline Oven - everything works fine - range and brolier start immediately yet oven clicks but does not heat anymore. Was working fine but no longer heats.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 18, 2011 | Maytag CWG3100A Gas Single Oven
Oven fan works but no heat everything else works
heatman101
Jan 04, 2011 | Ovens
The oven stopped working but everything else still workes what is wronge with it
heatman101
Dec 25, 2010 | Belling XOU270 / XOU271 Electric Single...
The oven isnt heating the lights n the everything else is on but it just wont heat
Oven not Working or
Oven not Heating
Oven Problems
heatman101
Dec 24, 2010 | Maytag CWG3600A Gas Single Oven
The oven does not work, the broiler works and so does everything else.
heatman101
Dec 23, 2010 | Frigidaire Ovens
OVEN WILL NOT HEAT. EVERYTHING ELSE WORKS, BROIL,
look closley at teh bottom bake element possible it has broken, causing this problem
Feb 09, 2010 | Frigidaire FEB27S5A Electric Single Oven
My scb2001kss ge advantium no longer heats. it turns on and everything else works, but heat
check breakers for oven one side could of tripped if everything else works but the heat this is a normal problem the only other thing could be is that the controles are not working
Jan 26, 2010 | GE Profile Advantium SCB2001KSS Stainless...
Ovens Logo
50 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
