Question about Cooktops
Gas injectors I've had a new hob fitted buti have come to realise when a burners is on its also making a windy kind of noise andi'n sure i can smell gas too. Do u think i've got the wrong jets fitted on there for natural gas?
  • 153 Answers
Well it is aproblem with the gas pressure u should get it checkded
Posted on Jul 22, 2009
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
New burner caps and hob knobs wanted for model 02-202110.\r\nthis model is obselete so what other make of gas hob is compatable.
Try calling http://www.selectappliance.com
  • Toll-Free: (888) 235-0431 (phone order hours: 9:00AM - 5:00PM Pacific time, Monday - Friday)
  • Phone: (650) 588-9100
  • Feb 03, 2011 | WindCrest 35 in. CTG365D Stainless Steel...
    Gas hob turning bottom of pots black..not sure if the hob is installed properly
    if the hob is turning the pots black the cooker needs a good cleaning they have air ports in the burner assembly they could be blocked or the incoming gas preasure to too high and needs to be checked by a gas engineer
    Aug 19, 2009 | Cooktops
    5 burner tappan stove. oven takes a long time to reach 350 and doesnt stay hot also a hissing sound when you first put on, called the gas co. and it wasnt gas leaking. a loud popping sound also
    By this description you gave it sounds as your oven burner has a flash back ,when it is like that does your flame look very yellow and gives off a Funny Smell ( which i Will think it is CARBON MONOXIDE . Remove the Oven burner make sure you watch for any wires attached to the burner (yes even in a Gas Stove) that would be part of your safety device . Make sure there is NO Rubbish in your Burner and your Burner
    Well . Clean it out Make sure your Injector is Clear Carefully replace your Burner Making sure it fits over the Injector ,Replace any wirer if you removed any and relight
    Jul 14, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
    Neff gas hob burner won't turn off
    yes it is sad to say
    Aug 23, 2017 | Cooktops
    No gas to hobs
    use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
    Nov 24, 2008 | Dacor Preference SGM466 Gas Cooktop
    Gas Hob Flame
    Hello
    Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
    The should be by the fittings (convertion fittings), you know?
    LP Gas to Natural Gas or Natural Gas to LP Gas.
    Hope this help
    Eddie Rentas
    Tupper Lake NY
    Jul 30, 2008 | Cooktops
    Flame on gas hob not correct.
    I'm not sure what you mean by a proper efficient flame. I just recently went through an experience I'll relate to you here. I purchased a GE Profile dual fuel range. I can get more specific if you'd like but here's the point. The highest burner on the range was rated at 17000 BTU's. A friend recommended the range to me and sang it's praises. I took delivery of my new toy and couldn't wait to get a pot on the stove to start cooking a long wait for pasta. Twenty minutes later I was finally seeing bubbles! I spilled the water out and measured 12 cups of water into the pasta pot at room temperature. That's three quarts of water. 20 minutes to see bubbles and never would it come to the expected "rolling boil". My experience has always been with electric ranges and I am new to gas but 20 minutes? Something had to be wrong, right? Wrong! Much research later I've found it is common for natural gas to LP conversion stoves to lose a good deal of their oumph when converted. GE as it turns out is one of the most notorious for a serious degredation in BTU output. After exploring GE's site I found that this same stove running under LP gas is rated(for the highest burner) at 11000 BTU's! No wonder I couldn't boil water! Back to the store it went and I am still in search of a stove that will meet my needs. Don't know if this will help you or if this is the same issue you are dealing with but maybe just maybe. Good luck!
    Apr 29, 2008 | Cooktops
    Gas cooktop BOOM
    Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
    Apr 03, 2008 | Cooktops
    Burner/Flame
    Hiya .. this could be due to a number of problems...... has the burner ever worked correctly?
    Is the behaviour with only one ring?
    1. If not... then it could be that the pipework to the hob itself has not been recuced sufficiently enough in pipe diameter to the regulator far enough back ...
    2.The regulator is faulty... in which case it can be replaced... however consider the cost of a new regulator and labour to fix it .. against the cost of a whole new hob... which should include a regulator. Is the hob still under warranty... if so use that .. but you will normally have to provide some proof it has been fitted by someone suitably qualified.
    3.the regulator may never have been fitted, which is dangerous and bad practice.
    Either of these scenarios... please ensure that you use a suitably qualified gas engineeer... I dont wish to be alarmist... but gas leaks and faulty gas appliances do cause unnecessary deaths...and is a silent killer.
    Regards Faggly
    Mar 26, 2008 | Maytag MGC5430 Gas Cooktop
    Cooktops Logo
    103 people viewed this question
    Top Cooktops Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Cooktop Expert? Answer questions, earn points and help others
