Question about Intermatic T1472BR Timer 4PST 208-277V T-SW
Have two 208 volts floods, want to put on timer Intermatic recommended then T17472BR Floods are presently installed on two seperate circuits. Do I need seperate 208v to Time clock and seperate 208v to line side and terminals do I use for load side for two circuits out to lights
  • tchdrafting Jul 22, 2009
    Voltage in to terminals A and B
    Seperate 208v lines in to say 5 and 1, load lines to lights terminals 6 and 2
    is that right
  • 19,396 Answers
Usually, wiring multiple units to single timer, you can use the same line in, and you separate just the time clock connections, so to use different presets for the two units.
The best thing to do would be contacting Intermatic at (815) 675-7000 for assistance and live step by step support in wiring the two units.
Regards.
Posted on Jul 22, 2009
  • Ginko
    Ginko Jul 22, 2009
    When you wire a timer to miltiple devices , this often can be done using a single line in, and connecting to different timer connectors the line out device. This mainly depends on the current draw of the appliances connected.
    Documentation made available by Intermatic is very poor, this is all we got: MODEL: T1472BR.
    For this reason I suggest contacting them at (815) 675-7000, so to get a technician following you by phone and ensuring you wire the units in the best way.
    Regards.
Show how to set the itermatic et821c
Following link has manual for Intermatic ET8100 series
Choose astronomic dawn-dusk timer -or- 7-day programming
http://waterheatertimer.org/Intermatic-ET-series-timers-and-manuals.html#ET8000
be sure to install two AAA batteries in compartment located on front just below the buttons.
Also reset the timer prior to programming ... and this will clear any conflicts or prior programming.
Timer default voltage is 120 volt AC. Choose 208-240-277 volt by moving selector switch located on back of timer.
Gene
Water Heater Timers Save Money
Jan 17, 2014 | Intermatic ET8215C- 7-Day Electronic...
How do i wire diehl t85 type 600
1) Copy following links for wiring Deihl T85 600 timer.
http://waterheatertimer.org/images/Deihl-Type-600-T85-timer.jpg
http://waterheatertimer.org/images/Deihl-T85-600-wired-for-208-230-Volt.jpg
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#T85
2) This timer will turn off Hot wire in 120Volt circuit.
3) For 208-230 Volt applications, the timer will operate by turning off 1 hot leg. However other hot leg will still have live power. To turn off both Hot legs, use DPDT spring-wound timer such as Intermatic 60 minute FF460M or FD460M
http://waterheatertimer.org/pdf/039_FF-series-sell-sheet-with-wiring.pdf
Feb 28, 2012 | Diehl Hardware & Accessories
Hello, I installed a T104 timer switch following the directions on the manual. I connected supply lines to terminals 1 & 3 and the load wires going to the pool motor on terminals 2 & 4. The clock...
It doesn't sound like you are getting a true 230 volts to the timer. Measure from terminal 1 to terminal 3. You should read 230 volts. If you are getting 230 volts between 1 and 3, return the timer, it's defective. If you are not getting 230 between 1 and 3, then you'll have to have a look inside the electric panel to see what has been miswired. There should be a 2 pole breaker with a white and a black wire connected to it that goes out to the timer.
May 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
I have intermatic t104 time 24 hour, the door hinges are broken can i get new door.
Page below shows Intermatic boxes, but doesn't describe which timer fits which box.
And the box costs as much or more than new timer.
http://www.electricsupplyonline.com/prod/intermatic-timer_accessories.php
Amazon sells T104 indoor
http://www.amazon.com/Intermatic-T104-208-277-Volt-Mechanical-Switch/dp/B000BQOX88/ref=pd_cp_hi_3_img
T104R raintight sold at Aplus
http://www.aplussupply.com/intermatic/timer.htm
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 05, 2011 | Intermatic T104 24h 208-277v Mechanical...
Can I use my Intermatic model T-103 switch for 2 separate 20amp 120v circuits?
Yes, the timer motor is 120 volt, so connect both neutrals from each separate 120 volt circuit to the "A" terminal. Probably best to place all the neutrals (line and load) under a wirenut with a jumper going to the "A" terminal. The terminals are intended for only two wires.
One hot will go to terminal #1 and the other will go to terminal #3. The 120 volt timer motor is connected internally at the factory to the "A" terminal and terminal #1.
Dec 07, 2010 | Intermatic T104M 208-277Volt 40-amp Timer...
I NEED A PROGRAMING MANUAL FOR AN INTERMATIC TIMER, MODEL # ET70415CR
Here are all the ET7000 series manuals
Click product number and drop-down shows manual
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Here is the ET70415CR manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et70415cr%20-%20english.ashx
This timer can be used for 120Volt or 208/240/277Volt circuits
The important thing is to install the 'voltage selector jumper' BEFORE connecting power
The jumper is supplied with timer
Oct 2010
If you need more help with specific parts of the manual, add a comment and I will respond
Oct 27, 2010 | Intermatic ET70415CR Electronic Energy...
Hello i have an intermatic model #t104r 208-277 volt my problem is that it works manually but it doesnt work automatically? whats wrong?
If you can also manually turn the dial so that the load turns ON and OFF, then the timer motor is bad :-( Replacements are available here for about $30:
Scroll down to "WG 1573", Timer motor 208-277"
Dec 10, 2009 | Intermatic T104R 208-277Volt 40-amp Timer...
Intermatic T1472BR Timer 4PST 208-277V T-SW Logo
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
