Question about Fuji FinePix A400 Digital Camera
Fine-Pix A400 is showing Focus Error and will not allow photos to be taken. In addition, the lens will not retract when the camera is shut off. This problem occurred after using the zoom procedure several times to obtain close-up shots. The camera has worked perfectly up to this issue. Can you suggest any solution to problem? Many thanks...
Here is a quick fix to try. If you attempted to remove the focus error doing the 3 times on and off, and it didnb't help to this. Power the camera on, you will hear the gear skipping as if it is slipping. Right at the moment you turn of the camera push the lens in manually slightly and gently. This will reposition the timing of the lens to focus. This usually fixes the Focus error when the lens is stuck in the out position and never retracts. I have had this happen twice, and it cleared both times by doing this. Good Luck
Posted on Aug 12, 2009
  • elextrixman1 Aug 12, 2009
    Let me summarize what needs to be done. Right at the moment you turn off the camera, push in on the glass lens assembly. Place your finger on the lens itself and push in, while you turn it off. You only have a second or so, or the camera will time out. Try it a few times, and you will see the camera will resync the lens to the proper focus position.
    Sniper:
  • 86 Answers
The manual recommends turning the camera on, then off again to see if it works. If not, you should contact Fuji for support.
You can call the Fujifilm help line and ask them. 800.800.FUJI
http://www.fujifilm.com/support/index.html
Posted on Jul 22, 2009
I had the E18 error--lens wouldn't retract and
Focus problems are quite common after a lens error, it sounds like you still have an issue with that lens unit. If you need help, there's a great site taht just specializes in the powershot problems, nothing else at all. Try going to www.camerasandparts.com and you'll see the fix for this for your SD890 camera. I hope that helps, that site is amazing for the powershots and that's where a lot of people go for help with these. Good luck with it.
Feb 21, 2010 | Canon PowerShot SD890 IS Digital Camera
E18 Error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. If there's any consolation, the A400 lens barrel is very resilient in its design, so there is some hope here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 11, 2009 | Canon PowerShot A400 Digital Camera
Canon PowerShot S2 IS Digital... E18 Problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 17, 2008 | Canon PowerShot S2 IS Digital Camera
FUJI FINEPIX S7000
Try it with a different set of battery. It is possible that one of your battery is "dead" or close to it, and the camera shuts down.
You have to find the bad battery.
It worked for me.
Jan 22, 2008 | Fuji FinePix S7000 Digital Camera
Focus error
maybe it has too little power
Jan 08, 2008 | Fuji FinePix A500 Digital Camera
Kodak v803
Lens is most likely been knocked out of place, that would be the reason why you have out of focus and/or blurry photos. This would also be the reason why you can't retract or extend the lens.
Gently pushing on the lens MIGHT fix the camera, but I would only try as a last resort. Sometimes all that is wrong is the gears get out of place, and by gently pressing on the lens, it snaps the gears back in line, which will bring the lens into working order again.
Nov 16, 2007 | Kodak V803 Digital Camera
Lens won't retract
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. Have already fixed two A400 cameras with this problem by using these methods:
http://www.e18error.com/repair.html
Oct 05, 2007 | Canon PowerShot A400 Digital Camera
Shuts off when I zoom or take photo
Sounds like zoom has sand in it, Or the camera may have taken a hit to the front of the len's, Lens has to be taken apart, Has to be done buy a camera repair shop/or factory. TC
Aug 25, 2007 | Fuji FinePix E500 Digital Camera
Zoom lens won't retract
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Canan powerhot a400 mallfunctions
Upper Indicator
" Green: Metering complete (two beeps sound)
" Orange: Flash will fire
" Blinking Orange: Camera shake warning / Insufficient exposure
Lower Indicator
" Yellow: Macro Mode / Manual Focus
" Blinking Yellow: Focusing difficulty* (single beep sounds)
* When the indicator blinks yellow, lock the focus before shooting.
lcd_focus_indicators_a70.gif The AF frame appears as follows when the LCD monitor is on. " Green: Metering complete
" Yellow: Focusing difficulty (When AiAF is turned on.)
Dec 06, 2006 | Canon PowerShot A400 Digital Camera
Fuji FinePix A400 Digital Camera Logo
648 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
