Question about Hitachi Cameras
We have hitachi KP-M1AN cameras on our vision systems. On one machine the camera will fade out or go out altogether. We have tryed new cameras and camera cables and they all do the same thing. Thanks Jon Granger
  • jgranger_1 Jul 22, 2009
    We have switched monitors with no luck. We have also switched computers and vision boards with no luck.
    Thanks
    Jon
    Changing the shutter speed seems to be doing the trick. I appreciate your time and fast response to my problem.
    Thanks
    Jon Granger
  • 336 Answers
Looks like you have already tried swapping cameras and cables. If you have individual monitor, have you tried swapping as well? Also, if you are connected to an image DSP or junction box, please try to change other slot of the camera that has fading image.
Regards,
Jeep Brainy
Posted on Jul 22, 2009
  • jeep brainy Jul 22, 2009
    Hi, Please try also to swap power supplies. Another to try is, to change the shutter speed and change the integration from FIELD to FRAME.
    Regards,
    Jeep Brainy
    Hi Jon,
    Another thing to try, please change the angle of the camera to other view and see if image still fading. You might be capturing a view with direct agle with sunlight causing your image to be faded.
    Thanks,
    Jeep Brainy
I have a Swann security system day/night vision cameras and the night vision has gone out on 2 of them and the system is less than a year old? Can any one help. Can these be fixed?
Check the power supply (usually 12VDC) and its connections. Lack of power for to LED's will cause the night vision feature to cease to function.
Aug 26, 2013 | Swann Communications Home Security
My grandfather has a Hitachi 50ux58b and is having double vision or shadowing -- whatever it's called and redness color fading-like. Was told it was a convergence IC that needs replaced -- uncle looked...
try not to do repair yourself. the tv holds high voltage even when unplugged. you could KILL yourself. If red is fading the convergence ic will not help. you need to replace all the guns. red, blue, and green. usually each tube or gun is around 300 dollars each.
Mar 21, 2011 | Televison & Video
Is there a night vision part to enhance vision for this camera?
Generaly most night vision cameras are of the infrared kind where you need infrared lights of typically infrared LEDs.If you can get more infrared leds towards your objects will be better.Or you can buy infrared lamps with independent power and similar to the ones you place on your front yard.I've tried it and it works.
Oct 27, 2010 | Logitech Security Surveillance Camera...
Camera alignment for fabri vision scanner.Used in sheet metal shop
There are 8 CCD cameras.Before I can help I need to know what kind of machine you have FV4600 or FV4800? or machine serial number so I can cross reference? Or you can contact the following:
Angel Lee
GaugeOne International
Fabrivision Service Specialist
email: gaugeoneintl@earthlink.net
Cell Phone: 818-381-1568
Mar 02, 2009 | Vision Cameras
Panasonic NV-GS35
The problem will disappear resetting the camera settings from menu, or removing camera battery for five minutes.
If the problem does not disappear, then the camera is faulty.
Jul 19, 2008 | Panasonic NV-GS27 Mini DV Digital...
Iv just bough a 4gb SD card for my for my hitachi DZ-BX35E. When i try to format it though it said card error and doesnt complete the formatting. So i need some help please.
I'm not really familiar w/ your Video Camera. But you 4gb SD card can take about 24,000 still pictures. From what I understand, the SD card is only for take still pictures and not videos. The Video Camera is designed to use the Digital Video discs for videos. 4Gb might be too big for the machine to handle. Hope this helps but really I'm not sure. Check out this website which talks a lot about the Hitachi. A lot of techie stuff too you can use.
http://www.pixelbeat.org/systems/hitachi_DZ-BX35E/
Jul 18, 2008 | Hitachi Cameras
New System old drivers
can you give me some FREE software!? i need help.
Apr 19, 2008 | eVision ClearView Digital Camera
Hard drive
Some hard drives will only work as a single device when jumper-ed as "stand-alone", try finding this option or alternatively, remove the jump altogether and try again.
Oct 23, 2007 | Hitachi Ultrastar 15K147 500 GB ATA-100...
Do the DVD-Cams have any editing functions?
Yes: Delete, Play List, Move, Divide, Combine and Fade are available when recording onto DVD-RAM discs. This feature is available by utilizing HITACHI’s Disc Navigation System. DVD-R discs cannot be edited.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Can I do any editing directly through the Hitachi DVD-Camcorder’s menu system?
When using a DVD-RAM disc, you can delete, move, divide, skip and repeat scenes as well as construct titled play lists and add wipe or fade video special effects via Hitachi’s Disc Navigation System.
Cameras Logo
Top Hitachi Cameras Experts
Parshiv Luthra
Are you a Hitachi Camera Expert? Answer questions, earn points and help others
