You did not state your model or make so I can't explain how to change your model but most vacuums you must remove the bottom plate held on by screws that covers the brush roll, remove the brush roll and belt and reverse the process with the new belt. Some models have the brush roll held in by screws and/or brackets, some brush rolls slide down into slots. Replace the brush roll if the bristles are worn or frayed. If you are not replacing the brush roll remove the endcaps if possible and clear any hair or debris that has worked it's way in there.
Cogged belts are different from stretch belts and do not need to be replaced at least once per year like stretch belts do. You should still remove the brush roll at least once or twice per year to clean out debris. Maybe more often if it gets hair or strings wrapped around it which can build up causing friction and heat which can melt or damage the brush roll or even the nozzle housing.
To change the belt on a Hoover Flair Stick Vacuum, remove all 6 screws from the bottom of the beater bar. There are 2 screws hidden under wheels. You must pop the wheels off with a screw driver to remove the hidden screws. The cogged belt is on the left side of the beater bar. Be careful not to pull the wires.
Remove the plate on the bottom front of the vacuum by turning the plastic knobs on the plate with a nickel or screwdriver. Then pull out the brush bar and slide the belt over the brush bar and align it with the "cogged" portion of the brush bar.
Slide the belt and brush bar up into the vacuum and over the small cog on the motor. You'll need to pull back the idler pulley which is the smooth metal cylinder next to the cog on the motor. Once everything is lined up push the brush bar into its slots and reinstall the bottom plastic plate onto the vacuum. Everything should be in good working order now!
Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
If this is a Savvy, then take out the screws for the bottom plate, then remove the screws that hold the top on, turn the vac over, and remove the Hovver emblem, there is a screw there, then the top cover comes off and you can replace the cogged belt.
The easiest way is remove the belt cover on the top housing, turn unit over, on the belt side remove the red plastic lock, one screw, then you can pull the brush roll cap out, take it off, then you can get to the cogged belt, look further in and you can get to the pump belt. You didn't which belt you want to change, if it is the cogged belt, check the end on=f the pump that the belt goes on, if the cogs are gone, you will have to replace the pump, if they are there, then just replace the belt and put back together.
Remove the belt cover, Turn the Bissell over, remove the brush asm. You can then change both belts. While you have the belts off, check the cogged gear on the pump, if it is stripped smooth, then you will have to replace the pump also. The gear comes with the pump and not separately.
You can change the belts from the bottom, remove the brush roll, then you can reach thru slot to change the pump belt, then the cogged belt. Wasn't sure which darwing you wanted, if it is electrical, let me know.
First take off the belt cover on the side,
then turn it over, on the belt end of the brush roll, there is a red piece to hold in the brush roll, take out that screw and pull it off, the you can remove the end cap and cogged belt, Put the pump belt up thru the opening and around the bigger part of the pump pulley, grab the belt from the top side and put it around the motor shaft. Re-install the cogged belt, brush roll, cap and red lock.
