Question about HP Photosmart C7280 Laser Printer
Duplex copying on HP Photosmart C8280 All-in-One Can't see how to do two-sided copy apart from scanning both sides and printing two-sided! Old HP printer could do 1-1 1-2 2-1 2-2 etc.
    Sniper:
  • 86 Answers
Open HP Solution Center, click on Settings, click on Scan Preferences, select "Scan both sides of original when using duplex feeder."
or
Open Solution Center, click on Scan Document, and you should have a check box towards the bottom of the window which would say 'scan both sides of the original document'. check that box and start scanning.
Posted on Jul 22, 2009
When I make a Duplex copying,it is copied at the wrong position only on the front side.
check that you are using duplex and left binding. also does this happen with other files??? does it happen with different program pdf , word etc.
Oct 20, 2015 | Sharp Mx-2310u Color Copy/print/scan
300ci will not copy 2 sided documents
from the copy screen touch the duplex button on the display and choose 2 sided > 2 sided. if it is not available in the menu the duplex unit may have failed repeatedly and shut itself down in which case you would need to go into simulation mode and perform a u906.
Sep 29, 2014 | Kyocera Taskalfa 300ci With Feed, Bank,...
I am using auto feed on HP 4345 MFP printer, the issue is I have documents with one side printed but printer is scanning both side and printing. How can I change setting to single side from Duplex scanning...
Mr. Agarwal
you have to turn off the duplex scanning option under copy settings this will solve the issue
You can go to settings and look for Copy setup or copy settings i dont remember well but you get an option of DUPLEX COPY or DUPLEX SCAN you have to turn off this.
DO RATE MY SOLUTION PLEASE
Saleem
Jun 30, 2011 | HP LaserJet 4345mfp Printer
I need to make double sided copies of a document. Please tell me how to do it on a hp photosmart C5580 All-in-one. thanks
The HP Photosmart C5580 does not support Duplex (Double Sided) printing, So you will only be able to print on both sides of a page by manually fliping the page over and printing on the other side of it. If you need it to scan both sides the same problem applies, as the scanner can only scan one side of the paper at a time. Sorry and Hope This Helps!
Mar 14, 2011 | HP Photosmart C5580 All-In-One InkJet...
Cancel double sided copying
Slide the DUPLEX switch to the one sided mode on the ADF.
Also you should be able to set the single and dula sided mode from your scanning application in the setup tab.
Oct 15, 2009 | HP Scanjet 8250 Flatbed Scanner
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
Missing the manual - how to collate??
By using the Duplex button on your machine, you can set the machine to
print copies on both sides of paper.
1 Press Duplex.
2 Load originals face up in the ADF.
3 Press the Scroll buttons until the binding option you want appears.
Off: Prints in Normal mode.
1->2Side Short: Prints pages to be read by flipping like a note
pad.
1->2Side Long: Prints pages to be read like a book.
2->1Side: Scans both sides of the original and prints each of them
on separate two papers. (SCX-6322DN only)
2->2Side: Scans both sides of the original and prints them on both
sides of a paper, this function produce exactly the same print out
from the original. (SCX-6322DN only)
2->1Side Rotate2: Scans both sides of the original and prints one
of them on separate two papers, but the information on back side
of the original is printed 180° rotated. (SCX-6322DN only)
4 Press OK to save your selection.
If the mode is enabled, the Duplex button is backlit.
Collation
You can set the machine to sort the copy job. For
example, if you make 2 copies of a 3 page original,
one complete 3 page document will print followed by a
second complete document.
1 Press Copy.
2 Load originals face up into the ADF.
For details about loading an original, see
page 5.1.
3 Enter the number of copies using the number
keypad.
4 Press Menu until Copy Feature appears on the
bottom line of the display and press OK.
5 Press OK when Copy Collation appears.
6 Press the Scroll buttons to select Yes.
7 Press OK or Start to begin copying.
One complete document will print
http://www.websitetoolbox.com/mb/copierquestions
Jan 23, 2009 | Samsung SCX-6322DN All-In-One Laser...
Canon imageCLASS MF6530; can't set up duplex (2sided) printing
hi there
there are 2 ways to copy 2 sided
one is full duplex which means your copier must have a duplex attatchment fitted on the copier lid
the other if it hasn't got a duplexer is to copy in 1 to 2 mode which means you have to turn the copy over. it sounds like your machine has not got a duplexer fitted but it can still do double sided using 1 to 2.
hope this helps
beergut707
Oct 15, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
How could i make a duplex copy, where do i have to go
Duplexor printing is the only feature which HP All-In-One printer offers, where you can print in both sides of the paper from your computer if you have multiple pages to print.
But SORRY you cannot make a duplex copy on the stand alone machine itself.
But still you can scan and print the same on the duplexor.
For Scanning Multiple pages in one Folder:
All you need to do is if the All-In-One Printer driver and software is completly installed in your computer, Then you should have a icon in your desktop as HP Solution Center / Go to
Start> All Programs> HP> HP Solution Center>
Then click on Scan document> The in the option where it says Where do you want to send the scanned documents> Click on the drop down and select PDF / Word then make syre you
have selected Show preivew Box> Then click On Scan>
After it shows the preivew> Click on I Accept> NOW IT WILL ASK IF YOU WANT TO SCAN ANOTHER DOCUMENT> Click yes on this and replace the document> and the click on
NEW SCAN> and follow the same steps to scan multiple pages, till you have finished scanning all and then> When it asks if you want to scan another document> Click on No.
And then print the same through the duplexor
Good Luck
Sep 27, 2008 | HP Officejet J5780 All-In-One InkJet...
Compatible with Microsoft Vista?
Not to worry, this printer is Compatible with Vista, but when it comes to Duplex Printing (Two-sided Printing) there might be problem, because in Vista Duplex printing doesn't works well.
Apart from that, this printer is the Best in the HP Photosmart Series.
Thanks
Riz
May 07, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart C7280 Laser Printer Logo
774 people viewed this question
Seeker5211
Seeker5211
