The clicking noise is created by flat spots on the fuser rollers. The flat spots on the rollers create a ?chatter? in the fuser gear drive train. This noise does not affect the performance of the printer and does not affect print quality.
All new fusers are shipped with restraints that keep the rollers separated during storage. If the fusers sit without the restraints installed for a period of time, flat spots can develop on the rollers which can result in a ?thumping? noise and will create a ?clicking? noise in the fuser gear drive train.
If a printer sits idle for long periods of time, flat spots can develop. If Power Saver is disabled and the printer sits idle for long periods of time while powered on, the flat spots will develop at an accelerated rate.
The clicking noise is created by flat spots on the fuser rollers. The flat spots on the rollers create a ?chatter? in the fuser gear drive train. This noise does not affect the performance of the printer and does not affect print quality.To decrease the possibility of flat spots developing, set Power Saver to On with a Power Saver Timeout of 30 minutes
To decrease the possibility of flat spots developing, set Power Saver to On with a Power Saver Timeout of 30 minutes.
If a printer or fuser is not going to be used for an extended period of time or will be placed in storage for future use, re-insert the fuser restraints. The fuser restraints can be in place and the fuser installed in the printer
SOURCE: xerox phaser 4500 print completed bubble notification
A networked printer shouldnt be turned off, but it will go into a sleep mode you can select how soon it does this.
-Carl, please let me know if this helps.
SOURCE: I have a networked xerox phaser 4500. I am trying
This notification is actually controlled in Windows... In XP, follow these steps...
For Windows Vista, it is more complicated...
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
To disable balloon tips in the notification area, follow these steps:
SOURCE: Xerox Phaser 4500 printer has
From the Xerox Phaser 4500 Service Manual (here), the main problems could be one of:
It could be that your fuser needs to be replaced, but as you can see that code relates to a couple of problems, so even replacing the Fuser might not fix the problem.
If it doesn't even do the warm up checks it is likely to be the fuser because the other components such as STS failure and cooldown won't have had a chance to run..
