Question about ASUS SiS Chipset P4S133 (P4S133/PA/LAN) Motherboard
Why when booting this messege is coming
Intruded chass is opened
  • 94 Answers
You cpu has opened perviously ,check cpu caseing is closed properly then go to biose setting and check security tab and save setting and boot normly suyyam@gmail.com
Posted on Jul 22, 2009
Boot warning chassis opened
disable the chasses intrution detection in bios setup.
Dec 23, 2013 | Acer POWER APS290-UC4201P MT CELERON M 420...
How to replace power supply
unscrew the screws on the back and open the chass. then draw a map about the connections where those power cables went into inside the chass. then unplug all the power connections and unscrew the screws on the back which fasten the power supply to the chass. remove other components if necessary to alow space for the power to come out. then replace the power and anything else in reverse order and reconnect the power cables according to the map.
Mar 02, 2012 | Acer L410G PHM19 3GB 160GBDVDR X1250...
The system intruded.chassis opened or tempered before please check the system. what shall i do ?
When you open the computer case, a switch is tripped and after the case has been closed and the computer boots up, you get this chassis intruded message.
To clear this message go to the BIOS configuration and then to the chassis intruder detect and then Reset this setting.
Oct 03, 2010 | ASUS P4SE Motherboard
My P4B will not boot. I am trying to install XP and all that comes up is "system intruded chassis opened or tampered before. Please check system. The installation is A-OK. what do I do. PLEASE!! Paul
This board has an Intruder protection sensor - practically it's a pair of pins (bottom right of the board) with a strap that when removed signals that the case has been opened. Put the strap back and it will be OK.
Jun 21, 2010 | ASUS P4B-M (P4BM1400WOLTINY) Motherboard
In boot come msg the system intruded not boot
This is a safety feature.
To turn off this feature open you're manual to page 1-15. Follow the instruction, item 2. Chassis intrusion connector (4-1 pin CHASSIS). If you need the manual download it from Asus; http://support.asus.com/download/download.aspx?SLanguage=en-us
At the time of this post Asus Global site is down for repair. Suggest you type, P4XP-X in the search window located in the upper right hand corner of the above link. Than click on:
P4XP-X related files for download
Cheers'
Mike
Feb 18, 2010 | ASUS P4XP-X Motherboard
My suzuki intruder is missing backfiring on the
Did you sync the two carbs? If not the rear may be getting all the gas from the rear carb and none to the front. Twist throttle engine off and see if front carb cable is pulling the carb open.
Also unscrew the spark plug boot from the front spark plug wire and trim 1/8th inch off the wire and screw the boot back in. The plug wire end may be corroded on that wire.
Feb 05, 2010 | 2004 Suzuki VS 1400 Intruder
Chassis Intruded
clear your bios, close very good your case, open bios disable chasisis open detected fro yes to no, (or in some model from enable to disable ) change saves exit booting and good work.
Apr 07, 2009 | ASUS A8R32-MVP Deluxe (A8R32MVPDLX)...
Problem at boot
There is a mechanical switch connector available to determine if someone has opened the chassis.
You can bypass this through the BIOS by entering the BIOS on bootup (DEL? message at bootup? F1?) then look for the system chassis intruder alarm and DISABLE
Another option is to find the pins that the switch is supposed to be connected to (documentation on the ASUS P4B motherboard) and jumper them.
Jul 03, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
ASUS SiS Chipset P4S133 (P4S133/PA/LAN) Motherboard Logo
51 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
